fisnik
fisnik's Achievements
New Member (2/5)
1
Full house renovation and retrofit guidance
fisnik replied to fisnik's topic in House Extensions & Conservatories
I realise that. Heating hot water cylinders is where heat-pumps are least efficient. I was thinking a 300 litre (or maybe more) heat-geek cylinder with the 6 meter internal coil set at a reasonable temperature (hysteresis) may not be so bad. My son likes to have a bath almost every evening (helps him sleep) Sometimes he will empty it and constantly run the shower if left unchecked. When he's having the bath so may end up like two bath fills. That's like 200 litres right there I guess. Plus if anyone else is also showering it may end up needing more. Would 30 minutes not suffice for the heat-pump to reheat the cylinder? I realise that they can only do one thing at a time heating or hot water but didn't think it would mean a few hours of no heating. If that's the case I'm going to need massive battery storage to make it work so no money savings there. I'm not averse to keeping the gas boiler for the foreseeable future. Just would be nice to go all electric at home. -
That's what I'm worried about. Will have to explore the costs of digging up a solid concrete floor. If we are doing that then we will definitely put in UFH. Although a heat-pump expert (I think it's Urban Plumbers on youtube) did his own house and said there's no need to insulate the floor as it would be nice thermal mass for the heat-pump to heat... -
I'm attaching the existing drawings as the house is now. Existing plans redacted.pdf -
Thanks. I am aware of that. My fear in terms of air to water heatpump is getting the heatloss survey correct given its a full renovation so can't use existing bills etc and also getting the design right. A Scop of 3.8 I would take with no problem. Hoping a flow of 40-45 and mostly UFH downstairs will help with that. I'm worried of having someone doing a botch job on it and get a Scop of 2.X and paying through the nose just to heat our home. I would go air to air but we do use a lot of hot water. -
Wow @Gus Potter. Thank you for the reply. All your feedback is much appreciated and of course none of it was patronising. You're right in that I hadn't thought about the steels. Although we considered that we may need quite a few and have spoken to our architect about hiring a structural engineer for the steel design we didn't think of the cost side of things. The aim was not to have any internal columns; I imagined that we may need a couple of square frames but perhaps I had that all wrong... 😔 The stairs are where the original stairs are so the design as such hasn't changed but they will be renewed. I'll post the existing drawings. I hadn't thought about demolishing all of it. I mean I would love to go brand new build if the cost was't much more. Certainly, will consider what you're saying as we havent even spoken to an SE, just our architect. So much to think about. I will speak to the wife and mull over a few things. -
I know who owns it. It would be all of the 8 properties that have access to it on the deeds. So I'd need to buy it from the 7 other homeowners. Don't think I'd be able to deal with the paperwork that would need. I was told that apparently you can get a party wall agreement and put all other 7 on it and that "might" be okay but I'm a bit weary of doing that too. -
Thank you @JohnMo and @Redbeard for the messages. The orientation is the frontage you see in the photo is south facing. It's nearly perfect south. Perhaps I should have explained. The house needs "gutting" because everything internally is really old. Artex ceilings, textured wallpaper, exposed central heating pipes, kitchen units falling apart, non existent wall sockets upstairs with old grey style metal consumer unit that is not fit for modern age. It will need full rewire and full new plumbing, new kitchen, new flooring, new everything. We're a family of five living here with three young children and we need to modernise our home. We bought it with the view of extending. Two of our children are special needs. Our 9 year old son is profoundly Autistic with high needs and will be living with us for the rest of our/his life. We're looking to add a sensory room for him. We will also potentially have grandparents move in once extended as they currently travel in every day to help out with the children and taking them to and from school. Me and the wife are both working full time. That's the reason why we're looking to increase the size of the house as much as we can. Also we need to alter the living space to open plan as we need to oversee the children and have line of sight. Our boy can really go for our toddler if he feels annoyed or any noises are made. 😩 In terms what would be a priority is renovation>extension> energy efficiency (insulation, air tightness, solar and battery for bill savings). The aim is to do it once, do it as best we can and we chose to wait and do it this way instead of having a mish mash of renovation and constant upheaval where you're doing a bit at a time. We're lucky that some years down the line after buying we can afford to do this now without putting ourself out financially. The drawings posted are just for submitting planning and not detailed. I will be having detailed construction drawings from my architect once we get the planning accepted. In terms of insulation the only old fabric of the house will be the frontage you see there. and the wall of the existing side extension of ground level. Hoping to do some trial holes and hopefully the foundations are good enough to add the second story on top. The house is definitely solid brick. The existing side extension is cavity wall from the 90s I expect (previous owners built it). I'll have to see if there's any existing insulation within it. I am mindful of this but I'm hoping to fill that cavity with beads. The access road is shared road for garages so strictly speaking I'm not allowed to put anything on the side externally but realistically maybe just 50mm EWI may not ruffle any feathers. The main neighbour that has most of the impact said he was fine with it. From our calculations we have the funds to do the renovation and extension as seen on the drawings and that is the priority. But with what would be left over also we like to get the best cost/benefit analysis in terms of energy efficiency/insulation and eco friendly aspects to our build. Currently we're hoping to not get a loan out but if something is worth it we will. -
Hi there. We're going to do a full house renovation including to the rear and side (2 story wrap around extension) and loft. As you can see from the pictures there's already an existing single story side extension. We'll be adding another level to it on top and extending to the rear too. All the family will be moving out and the house will be entirely gutted to the brick so it's ideal to install any insulation and whatever else possible to make it as energy efficient as possible whilst the works are being done. The problem is the budget I was envisaging whilst substantial it will be mostly eaten up by the extension (probably). I don't know how much funds we'll have left to do a lot of the intensive adaptations (like super tight airtightness, MVHR, also dig up the concrete floor and insulate). Getting an idea of what materials and methods and their cost, might help to decide what we should drop out from doing. Current original fabric of the house is solid walls 1930s built. Just on the face of it what kind of insulation specifically I would be looking at in terms of what materials, internal or external insulation or a combination of both? Although it would be nice, hitting EnerPhit levels I imagine it would probably be too costly and impractical, but I'd like to get some way towards it if I can and if I can do it on the cheap and do some of it myself I'm up for the challenge. Even if it just enough so I can go for a heat-pump and not worry that it's going to cost me more than my current gas boiler in bills. Dream is to have solar, battery and heat-pump and disconnect the gas. (I may need more help later with this aspect later on) We're about to re-submit our planning application as we had a hiccup and were rejected, the plans that I've attached are more or less what we'll be ending up with though. I'll still be getting quotes from builders etc but I'd like to have plans in place that include the insulation aspect. Any guidance is much appreciated. House extension plans.pdf
