They recommend 35mm copper. I haven't finished the installation yet but I have concerns about the 28mm.
I guess I should re phrase the question. Would a buffer help to solve this issue? The heat pump could feed the buffer, there would be a larger volume of water that could then supply the heating system.
The flow and return to a 10kw heatpump is in 28mm copper. The manufacturers reccomdation is for 35mm. The piperun is around 8 metres.
It isn't really possible to change the pipework as the flooring has been laid over the duct.
Is there a solution to help with the flow rate? If a buffer was installed, would this help to have the heatpump feeding the buffer and the flow from the buffer supplying the system?
