Bettie
Everything posted by Bettie
  1. It is grade 2, it’s a terrace of about 5 houses and I think each whole house is listed. Thank you.
  2. Brilliant, thank you ! Would you have any idea how much this might cost and do I have to use a listed buildings builder ? Thank you.
  3. Thank you for your help! In the survey it says that Kitchen and bathroom (both downstairs) have concrete slab, it's only the front room that has timber. It also says the ground level is approximately 150mm above internal floor level. There are no air bricks. It says that the cement plinth and sunken pocket had been covered and/or filled resulting in significant rot to the ground floor timbers. I can't see any request to the council to put air bricks in.....
  4. it is not a retaining wall. I am not sure about the Newton layer.
  5. Thanks Peter, that sounds great. These are the suggestions from the surveyor 2 years ago. Instead of doing the suggested work the owner left the property empty and are now selling it. Would you know how much it would cost to put in a suspended floor with insulation between the joists and allow the underfloor to breathe with cross ventilation and air bricks in 11m2? Thank you.
  6. Hi, I have just bought a small listed 2 bed cottage. One of the rooms on the ground floor has had bad damp and the whole floor needs replacing. Apparently it’s been unlived in for 2 years. There are 2 options in the picture below, please can anyone tell me a rough cost to get either options carried out. I’m in Hertfordshire. I’m trying to do the budget for the renovation but this is one area I’m not sure on. Thank you !
