Started my build in 2008. Single handed to complete shell in 2017, in between working and injuries. Pushing on with internal fit out at the moment and will post photos later, but for now I have a problem I need to resolve.
	The house is built on rock. the metre box is on the external wall of the garage. Rock to ground level is 525mm. I have a boundary wall, which runs parallel with the garage, 1500mm from the metre box. I have built up a 600mm raised flower bed 500mm wide attached to boundary wall 5 metres long, leaving a path 1 metre wide between the garage and the flower bed.
	The standard earth rod  1200mm x 5/8 inch has been placed in the raised flower bed. It goes right down to the rock and backfilled with topsoil. Earth cable is run in a length of 25 mm pipe under the path.
	My electrician can only obtain an electrical reading of 285 at every socket inside the house. This has to be brought down to below 200  to comply with regs. I don't think he has come across this situation before as I haven't seen him for a month.
	So,  the question is :-
	Has anyone come across this situation before and how did you reduce the reading to below 200 ?
	I would appreciate any advice given.
	Thank you all for your kind attention.
	Freddie
