Dantheman123
Everything posted by Dantheman123
  1. There is a parapet on the flat roof to take the frame and glass. So the only rain will be from the natural fall of it. There is a new gutter for all the main roofs above so that will get diverted away from lead and glass.
  2. What is an alternative though?
  3. Brilliant, thanks for this guys! Can the lead that wraps over the parapet be glued to pvc as seems that with a bit of wind it and heavy rain it would be trouble.
  4. So do these slot under the side rails or butt into and then seal between the two?
  5. Sorry I meant for the glazing, do they just slip on and cover tape?
  6. Thankyou for this, so much help. What do you the trims look like, how do the trims and the side rails become weather tight?
  7. That has been left to another trade, they are coming back in the morning to finish that off. So in regards to the ends of the glazed panels can they be left like this or can there be end trims installed?
  8. It was a sealed unit like a window and they had to cut the bottom of as someone messed up measurements I assume. Want to clue myself up before I start asking questions to the contractor. So do these ends need to be sealed? And if so is it and easy job?
  9. Hi ? Contractors have left today and curious to know if the ends of glazing should be left like this...
