Pep
Everything posted by Pep
  1. Apologies for my late reply, Craig. Thanks, I think what you said was helpful.
  2. Craig, Thanks for your message. Currently looking into the system as per the attached files. I've uploaded drawings of the fixed and the movable sash cross sections. In my case, the threshold would be removed on the movable sash picture. Thanks again.
  3. Thanks for your reply, Russel I have checked some pdfs however they show the drainage system only when the lift and sliding system is used as a patio door and not as a window. I decided to post here to find out if someone had previously come across such a problem? So any other suggestions would bre greatly appreciated.
  4. Hello everyone, I am planning to install a lift and sliding alu-clad timber window in my property. I have attached a vertical cross section of the wall on which the lift and sliding window is going to be mounted. The window will be installed on the outer edge of the wall however I am not sure what sill/drainage system should be used in front of the window so that water is drained away and prevented from coming into the space between the cedral click and the outer edge of the wall? Any ideas/thoughts would be greatly appreciated as I cannot find any solution online that would work for me. Thank you.
