Casti
Everything posted by Casti
  1. Don't have a nail gun, and impact driver needs replacing. Have a drill however. Do you think M10's at 600c/c is a good compromise?
  2. I suppose this might work in terms of dealing with not fixing plasterboard to warped joists provided the counter battens remain flat. If I did proceed with sistering the joists, would bolting with M12 bolts at 1200mm centres be suitable (noting the above re washer plates & double toothed connectors).
  3. Hello! I've done quite a lot of searching and even more reading and have ended up with even more questions. The background is, I am undergoing an extension in my house and am undertaking the majority of the internal building works save for plastering. Within the upstairs front bedroom (this falls under the existing property and nothing to do with the extension) whilst removing the existing plaster from the walls and the lath and plastered ceilings, it is clear the ceiling joists are undersized (appear to be 75x38 deep timbers at very rough 400mm centres with a single ceiling binder of same section size at mid span, there are some 2x1 looking timbers which are nailed in to every other joist back up to the roof rafters - will add photo later for clarity). It is clear they are undersized (3m span) due to the give away sag in the middle of the joists, and by the by they are well and truly warped and won't be good to receive plasterboard. I've decided the route I'd like to take is to sister the joists with some additional 3x2s (approx. 70x44 kiln dried timbers). I intend to install noggins at midspan and at perimeters to stiffen the ceiling and possibly compensate the removal of the existing ceiling binder with two at third points. The reasons I've elected to go down this route are I don't want to replace the joists with deeper more suitable joists as this would add significantly more time to the project (and possibly cost) The rest of the existing rooms (smaller spans) have same size joists so the floor in the loft would be at different levels and at the moment the loft has not got any boarding so all the joists are visible from above, but in the future I would like to board them with t&g loft chipboard for ease of access and possibly very light storage (<0.1kN/m2) In terms of joining the timbers together I think the route I want to take is to bolt them together with some M12 bolts at 1200 centres. I'm intending on drilling a 12mm hole and hammering the bolt in tight (so there's less chance of slip in the joint), using a double sided toothed timber connector between the joists, M12 washer below nut and bolt and large square washer plate against the timber faces. If anyone could comment on the above and give any suggestions for my proposals it would be much appreciated. Please let mevk now if any more information is required. I'll do a sketch of my proposal and attach with some photos of the existing ceiling/roof construction later. Thanks!
