I also want it to be breathable, for the wood, but yes it would be good to stick the tiles in place somehow, some have dislodged. Maybe just a line of froth across the tile tops would do it.
I'm also concerned about the stapling being good enough, maybe I will nail in a batten to stop water getting past the sides. It is a huge roof, and the tiles are in good condition. It would be a massive job to re-roof it and there are more important jobs that demand the budget.
The PVC waste pipes is rated to support a 10,000 lbs load, probably less with a couple of notches cut out of it, but it must be strong enough to support 220lbs of me (& ladder) leading at a 25 degree angle (~220lbs).
The strap only holds it in position, there is no additional force other than hand tight.
I want to put insulation between the rafters, but first I have to install a damp proof membrane, which I intend to staple between the rafters. I'm not sure I trust the purlins to take the weight, besides laying the ladder against them would get in the way of the work. A modification I may make to to cut a piece out of the ends so that it cannot slip sideways on the rafters.
It has a wider bottom piece, however I will use another strap around the mid point of the ladder and then around the rafters to keep it locked in position. Then I just have to worry about myself slipping off.
