Hi all.
I am in the midst of designing my MVHR system for my house I am renovating.
I am happy with he design on the whole but I have one room that I am not sure about the vent placement, indeed even if I should have supply vent in that room at all.
I have attached my proposed layout / vent placements for the first and ground floor. Any comments are more than welcome.
I have also attached a ground floor layout marked up with a 3.5m distance between a supply and extract vent.
My question is this a great enough distance to prevent short circuiting?
Also do I even really need this vent? I added it to help bring down the air velocity in the main air supply vent on the ground floor.
I realise the ducting takes a convoluted route on the ground floor. This is because I am dropping the ceiling level every where on the ground floor by around 100mm to accommodate services except in the hallway.
All vents located near corners are 350mm away from walls.
Also would you normally put the vent in the bathroom above the bath / shower area?
Thanks for any advice.
Dave
EDITED TO REMOVE PLANS, PLEASE SEE POST FURTHER DOWN FOR PLANS
