Hi Folks, hope you're all well. I've recently received full planning permission to build a new three storey end of terrace house in the side garden of my existing house in Leeds. There's a decent amount of space so the new house will be about 50% larger (about 200m2) than the existing 3/4 bedroom house. It will be just 6 metres from a 40mph road though. I'm thinking of using ICF because it's a MMC and it's quite airtight etc but mainly because it's good with external noise. Obviously I'll need half decent windows too (please sing out if anyone has fitted windows in a house near a fairly busy with good acoustic results). My main concern with ICF is the expense and warranty fuss of brick slips (the front and rear elevations must be clad in brick to match the existing houses - totally understand that but sadly they are the ugliest bricks man has ever conceived and I'll likely have to spend a fortune making the new house look ugly too). Can anyone recommend an ICF system that works particularly well with brick slips and and particular brands of brick slips. I contacted the LABC warranty folks. At first glance, they don't think the Elastolith acrylic brick slips that I'd seen will be acceptable and generally favour a brick slip system with a cavity behind it - not good news as that'll increase the wall thickness and fuss. Anyway, any advice would be much appreciated. I love the idea of building the house in ICF but the cladding issues are really putting me off and I may have to revert to brick and block.
Also wondering whether to go for brick and block on the ground floor and metal web joists on first and second floors to make fitting the MVHR easier. Any other suggestions? In a related issue, also unsure whether to go for underfloor heating on the ground floor only or all three floors.
Currently trying to tweak the design with some fairly minor non-material amendments.
I'm still going (thanks if you've made it this far) - I also have to have a phase 2 physical Coal Mining Risk Assessment and a physical Contaminated Land Survey (about £6k/granite worktops). It's in a high risk area for coal mining (as apparently 15% of the UK is) and there were three small Victorian terraced houses on the plot previously that were demolished to make way for the new, ugly, 1975 terrace here today. Any advice on that front would also be appreciated.
Many thanks,
Pete
20004 A-23B Site Plan As Proposed 17-Dec.pdf
20004 A-25B Elevations As Proposed Sheet 1 of 2 16-Dec.pdf
20004 A-24B Plans As Proposed 16-Dec.pdf
