Jose F
Everything posted by Jose F
  1. Thats an interesting point, I'm not sure! If there isn't already, would doing this now be a fix or is it too late? Thanks
  2. Not sure about these points but I will be getting it surveyed! Thank you for your input
  3. House I am looking to buy! The horizontal cracks are on the one side, most of the vertical cracks are on the next wall around, with one on the another side. Mainly on the two walls next to each other. Yes I am told the windows are fairly new too, not sure about lintels. The house was built by the man who lived there all his life. Do you think there could be a way of fixing this or stopping it getting worse? I am concerned a wall might fall down or something! Probably overthinking! Thank you
  4. Would a lack of expansion joints cause the crack to go through to the inside? Can this be rectified? Thanks
  5. Thanks, do you know what can be done about this? If anything?
  6. Hello, looking for peoples thoughts on what these cracks might be on this house? Horizontal and vertical. The vertical cracks don't go through the brickwork to the ground, but the one near the corner where it goes into the window and out again at the top goes right through and can be seen inside. The walls are single block built 1960s. I am concerned it could be subsidence? But I would have thought the cracks would be seen going to the ground as that's where the movement would start? It looks like the cracks have been patched up in the past, but the plaster has cracked again! I would be grateful to hear peoples thoughts on what this might be! Thanks
