Hello all,happy new year
I'm in process of building a 4mx3.5m garden room to house a few aquariums. Im wanting to do a concrete slab that finishes just above the surrounding land and have the concrete as the floor inside the room this will help with the 2.5m height ive got to work with.
I've dug the area deep enough to allow 150mm of compacted type 1 mot......25mm sand 100mm insulation and 150mm of concrete. However ive joined a group on Facebook for home builds/offices etc and had a few people say that a slab built in this way won't be strong enough. The walls will be 2x4 then osb and cedar cladding and roof 2x6 with osb then rubber so not exactly light but far from weight of brick building. Ive been advised to do trench foundation and blocks to height of floor then concrete in the middle, is that really necessary for wooden building?
Id also like to insulate underneath the slab, ive seen videos of people lining the bottom and sides of the form with insulation boards and then pouring the concrete onto this. Would this be good way to do it? As you can probably tell im no builder ?(car trade) and im quite confused as the best way to do it. If someone could help me out or point me in the right direction it would be much appreciated.
Thanks ?
