Russ P
Personal Information
  • Location
    Shropshire
Russ P's Achievements
Member
Member (3/5)
9
  1. Is there’s a certain adhesive you have to use for the vapour boards (foil backed)? trying to stay away from foam backed due to the rooms being small already
  2. I was hoping to avoid batten and board as the 2 of the rooms are small already. The outside is already rendered and painted and I’ve not had damp issues in the 3 years I’ve owned it so far. I was told it was the standard foil backed plaster board that can be dabbed
  3. After some advice/guidance I have stripped a late 1800’s cottage back to brick and currently boarding it. Is there any method to dab a vapour board to the external walls? I was always under the understanding they had to be hardwalled or batten and boarded (not keen on this method as don’t want to loose depth) but was told by someone a few days ago I could dab vapourboard
  4. Thanks for that. I know I know I need a buffer tank but I've looked high and low and without ripping my entire bathroom apart again (not and option lol) I have nowhere for it. i came across a picture finally last night off wunda
  5. It's 2 55metre runs. My boiler is sat right above my ufh manifold in the same room. My main question is.... do I need the circulating pump on the manifold with it being connected to a combi boiler? And to run a thermostat on rad system and thermostat on ufh do I need 2 2port valves?
  6. It's a Worcester boiler so I'm guessing pump is in boiler. do I want a 2 port valve on ufh and 1 on rads? So I can control separate?
  7. Ok I know everyone is going to tell me buffer tank but im looking at the system without a buffer tank. I am planning on running a underfloor heating system in 1 room and rads in rest of house. Running of the boiler with a separate stat on the ufh. It's a combi boiler. do I still need the ufh pump on the manifold and also do I need to put any 2port valves in anywhere to run the 2 Seperate stats
  8. Are they based in telford or is that company name
  9. Telford end???
  10. Them Buffer tanks ain't cheap are they ???
  11. Central heating confuses the shit outta me that's why I leave it to my cousin lol. All I knew is it would be a ball ache to get enough radaitors in that room which is why I chose UFH
  12. Hmm there's no room for a buffer so I suppose I could run it into the current heating system and the just control the radiators on the smart stats. I tend to leave my heating on all day during winter to be fair just on a very low heat all day
  13. It's a Worcester combi Boiler but I leave all that to my cousin as he's a BG engineer. There is only 1 radiator downstairs now which will never be on due to a log burner being installed. And 3 upstairs 1 in each bedroom as bathroom is running electric ufh. I've taken 4 rads of the system but it will only really be 2 of the rooms on as I prefer a cool bedroom. But I am looking at installing a smart stat system throughout the entire heating system so I can control each radiator
  14. I gave myself a target and luckily I met it. Was hoping to get away for a long weekend to the coast but wife was too late booking it??
  15. ill re do it shortly when I get up. It's not being connected to the boiler until next week so I've only done it from the mains just so it wasn't empty. I don't think it's too bad to be fair will just be a few bumps where I very quickly troweled it at the end but it's not being tiled!! It's having golden fossil paving slabs so will be laid on a bed of compo over the winter when I can afford it again
