Technoheckno
Personal Information
Location
Northumberland
Technoheckno's Achievements
Member (3/5)
1
Anonomised drawings attached. The site is on two levels the lower level has an existing structure that was a builder's workshop about the same size as what is proposed built of block, timber, glass and concrete/asbestos. The upper level of the site is c2.5-3m higher than the front. propfloorplan2.pdf propelv3.pdf PropSite Plan1.pdf
I guess that when the plans were drawn and submitted the architects had a 'passivehaus' qualified architect who drew the original plans but he's quit and left the country so now I guess they'll have to outsource all of the checking and detailing. Maybe I should have gone for an aggressive house instead.
Hi, After a delay of several years due to the incompetence of those who administer the Land Registry charges register I've finally got planning permission to demolish an existing disused builders workshop and build a two bedroom passive house. The ground floor would be built into the bankside so as well as the demolition there's quite a bit of muck moving, and retaining walls to build. Total floor area is about 212Sq m.
Hi, I own the plot on which I want to build and it is covered by two title deeds. One of the deeds shows a charge registered against it. The charge was for a period of time which expired 6 years ago. Does anyone know how I set about getting the charge removed as the title will be required for a section 106 agreement. Thanks Al
