Tiaan davies
Tiaan davies's Achievements
New Member
New Member (2/5)
0
  1. Steamytea Building is around 50 years old and yes they do this finnish on cornish units
  2. Temp Where can I find a page that specifies what building regs requires so that I can show a building control officer once he's on site, any ideas please Also the building was only bought recently and it is currently tenanted but when I viewed the building before purchasing it seemed a solid floor! There is no timber work in the building as far as I know, it is concrete posts and slabs for the building and steel frame for the roof which are also buried into the ground as pictured No signs of any water leakage so I think it's pretty water tight and sturdy building just interesting to see what building control think
  3. Joe90 I would be looking to rent out if possible Temp I know there's no insulation in the floor and as for the windows yes I think a few will need to be changed to accommodate fire exits. No oil storage tanks near. I'm hearing people that I've spoken to locally say that it won't get passed unless it has a cavity so the actual building structure itself is what worrys me the most and how to get it to pass cheers
  4. Thanks for all your replies I am hoping to finnish the outside as a EITCS thermal composite finnish to blend in with other residential finnishes in the area. I intend on possibly splitting the building into 2 self contained flats. Just want to know if anyone has seen similar and will building control pass the building structure or will I have to modify it in any way Cheers
  5. Not too worried about planning as it's in a residential area As for building control I need to know if it's do able to insulate the existing building or make some changes to it so that it can b used for residential.
  6. Hi i am looking into converting my commercial building into possibly a residential bungalow or something similar, as you can see it is a pre fab building. Was just wondering if i can anyway make this into a residential building that approves building regs and if so how can I do this. All ideas welcome Thank you
