Michael1965
Everything posted by Michael1965
  1. Hi again I just had a look at the frametherm 35,,, wouldn't that stop the air circulation? Thanks again for your help , Michael
  2. Hi guys thanks for getting back to me,,, at the moment all I can tell you is the lower half of the house is brick, the upper half is ceder shiplap cladding, which isn't bad condition but has been recommended by a previous surveyor to be changed, I've not seen between the walls yet but as soon as I know more I will come back here, I've heard that I'm not supposed to fill the cavity! Well with rockwool but not sure if I can use anything else?? I was just going to replace the plasterboard with something better, I will check out the frame therm, regards Michael
  3. Hi everyone,my first time on here, im in the process of buying a 1975 timber framed house,,, I've been left to believe that there is no Insulation in the cavity walls, I am thinking removing the inside plasterboard and replacing it with kingspan k118 ,,, does anyone know whether this will be ok to use? I would also like to know if there is anything else I can use within the cavity? My local council are as much help as a chocolate teapot!! Regards Michael
