Emmerski
Everything posted by Emmerski
  1. Does anyone understand what the following bold and underlined actually means please...? the enlargement shall be constructed so that – (i) other than in the case of a hip-to-gable enlargement or an enlargement which joins the original roof to the roof of a rear or side extension – (aa) the eaves of the original roof are maintained or reinstated; and (bb) the edge of the enlargement closest to the eaves of the original roof shall, so far as practicable, be not less than 0.2 metres from the eaves, measured along the roof slope from the outside edge of the eaves; and (ii) other than in the case of an enlargement which joins the original roof to the roof of a rear or side extension, no part of the enlargement extends beyond the outside face of any ex noternal wall of the original dwellinghouse
  2. We've been quoted £4000 to lower 3 rooms ceilings in order make enough head height for loft conversion. Is that about right!?
  3. That's what I thought too! It's a ground floor extension so no "roof" volume space. So as long as we stay within the cubic meters for the hip to gable and rear dormer we fall within the PD?
  4. Hello all, Any clarification would be much appreciated. We have a bungalow to which we added a single storey rear extension under prior approval with no problems, permission was given in 2016. This extension is 6 meters out and just under 7m across with a max height of 3m. We submitted a full planning application to extend into loft with a small front dormer, hip to gable and rear box dormer. A porch was also showing on the plans. This was refused. We have started building under what we believe is PD, hip to gable, rear dormer, set back as it should be and no not more than 50cubic meters. However, I am really confused about Part B of the technical guidance for PD that states something about ant enlargement to dwelling house being taken into consideration for the loft volume limits. My question is, will a single storey extension on a bungalow count towards the loft volume? Or are they referring to roof space as in pitched roof extension? We have started building and I am so confused! There is a bungalow opposite that has received PD for a loft conversion and 3 meter extension which by our calculations would still take him over the cubic volume limit. Many thanks in advance.
