Freddieab
Everything posted by Freddieab
  1. Hi All, I have searched high and low for the difinitive answer to no avail. Perhaps I have been using the wrong search term. In essance, I am moving to a bungalow in a rural location on approximately 1 acre. It will be my sole residence and is not a conservation area, heritage site etc and is not listed. It is in a CIL area. I understand, mostly, how CIL works. However, is it an accumalative charge? Initially I want to build a storage building of approximately 120m2 in one corner and demolish a dilapidated storage building, still in use, of about 25m2 in another corner. New floor area 95m2. The building will be within permitted development rights, no article 4 in force. All good so far. I believe I will need to apply for the CIL releif before starting etc and I believe there will be no CIL as it is under 100m2. But...... I also want to build an extension under 100m2 six months to a year later and possibly build another storage building under 100m2. Will the floor area of the first building need to be added to the floor area of the extension, and possibly second storage building for calculating CIL for those structures? Or is it only applicable to each new structure prior to construction. i.e. could I build 10 structures under 100m2, within permitted development, several months apart without incurring CIL? (I am not doing by the way!) For example everything you build is a percentage of the original plot and adds up as you go, but does CIL work the same? Thanks for any advice.
