Hello - I have a self build / designed home, and we have a free standing Heat Pump ( air to water) with a vertical Fan on top. I recently replaced the fan & fan motor as one of the blades had broken. ( This site helped me clarify the fan type I required). I had an electrician wire it in with the new capacitor. It heats a small swimming pool. It worked fine for a few days, then suddenly decided to Ice up badly at the weekend. The frost stat kicked in and cut it off. It was a warm day so I would not have expected that to happen. After it had thawed out, I checked everything still worked ok - and it does. It has never iced up before, and I am wondering if the new fan is too powerful and has caused the problem? I did in fact get a slightly smaller fan blade diameter than the original, as there were none at the diameter I required, so I would be surprised if it is? It draws air in through the sides, over the refrigerant coils, and then eventually blows the cold air vertically out of the top after the heat extraction . It is housed with ample free air space around it, but it is clearly condensation badly for some reason. Last year I had new refrigerant put in when a small leak was repaired. I am wondering if possibly that leak has returned, however the operating pressure meter seems to read ok? It seems too coincidental that this has occurred only a few days after changing the fan. The fan sucks and blows in the same direction as the old one. The HP is now 10 years old and we are fed up spending money repairing it when perhaps we should have a new one installed. The company that repaired it last year has now dissolved and so before I engage another professional engineer, I just wondered if anyone had any thoughts, suggestions or advice in case I am missing something obvious. If I get a professional engineer , should they be able to test that the compressor & condenser are working correctly? Any ideas welcomed. Thanks.
