Thanks so far.  I think the builder is quoting a recommended upstand against a British Standard so I may be mistaken.  My technical manual, however, does say that the parapet wall should have an upstand of 150mm and this can be reduced to 75mm under the patio door.  I can’t see any exclusions in my policy accepting responsibility for a lesser upstand of 30mm.
	We have had loads of issues with this roof and the warranty has already paid to correct some problems but this has uncovered a number of other factors that I wanted to correct whilst the original work was being completed and not have to do them later.  It’s a complicated situation but these are the issues that I have identified:
	1.  The roof is flat, like really flat, with no fall.  This was an error in timber frame design that wasn’t picked up by the architect. The technical manual allows this if the covering comes with its own 10-yr warranty which it does.  There is a drain to the side of the deck which allows most of the water to escape.
	2.  The patio window is fitted into the timber frame and not into the masonry.  This meant that the cavity gap had to be sealed.
	3.  The windows fit the aperture in the frame almost exactly leaving little room for manoeuvre and definitely no room to vastly increase the upstand or give loads of room to correct the lack of a fall..
	4.  The existing roof covering is EPDM and this has been incorrectly installed at corners and and joints but has not yet failed.
	My minimum proposed works to correct the above is as follows:
	1.  Remove the membrane and deck and construct a fall.
	2.  Replace EPDM with GRP.
	3.  Move the patio window outwards to be sealed to masonry and bridge the cavity.
	The builder is unsure or whether there is enough upstand to allow a suitable fall and suggested the shorter window for the rain splash issue and fall.
