PeterFenton
Everything posted by PeterFenton
  1. Bit stumped and can't work out which way to do it. I have a Worcester Boiler , with 8 rooms underfloor heating , upstairs / games room normal radiators. I have put a zone valve on the upstairs / games room run so that underfloor heating can be set to run 24 /7 albeit low over night / during the day just to keep the block warm ish rather than heat from cold each time. I have a Honeywell STC 9100C programmer running the upstairs / games room but have yet to wire in the zone valve so its on manual at the minute. Underfloor heating needs 3 more room stats connecting before I can fire up so I am close. So the problem I have is wiring the Zone valve which I thought I could wire into the Honey well and it should work when the timer is on but the valve seems to have other ideas and I notice the heating was on this morning when the timer should have shut it off. Wiring I have Honey Well Earth Neutral Live Live -1 link Brown Wire -2 Blue Wire -4 these go to the boiler Live in and Radiator link Zone Valve I wired into Earth Neutral Live which powers valve then Grey into 2 and Orange into 4 assuming it would open when timer came on and switch off when timer closed But it doesn't Any ideas
  2. So after the roof conversion comes the DIY finish it off , Roof is on watertight and basically finished but the decorating , heating and wiring need doing still. Also decided on underfloor heating so that has added a further complication to the situation , as having to live in the house while I do all of these things
