Property is a 1950's pre-cast concrete mid-terrace house, with a flat roof. All walls/floors/ceilings are cast concrete.
The roof covering is around 15 years old, and appears to be in fairly good condition. It is of a torched felt construction, with (I assume) timber cavity underneath, with some form of insulation.
First leak was several months ago, I had a look, and noted a few small areas of cracking around a drainaway. Roofer came out and laid around 1m2 of torchon.
Leak vanished over night. Perfect. Ceiling coverings replaced.
Fast forward a few months, and its leaking again. Yet, and this bit hurts my brain......It only tends to leak into the property when it is DRY/fair/warm outside. We had a week of rainstorms, and not a single drip came in. yet it was nice and sunny, around 14 degrees a few days ago, and it was dripping every few minutes.
Is it possible that this current ingress of water is simply water that is 'stored' in the insulation, following the first leak?
If that IS the case, I'm assuming I am looking at a full strip and re-laying of all wood/insulation/membranes?
