rosswilliams21
Everything posted by rosswilliams21
  1. Russle - do the foil backed boards not act as a VCL if I use foil tape of the joints and rafter? regarding ridge vents then it may be a case of asking BCO, I can just jump up and fit a dry ridge system when i fit the velux so its not a massive inconvenience but I would rather not if I didnt have to. Thanks for the advice really appreciate it
  2. Brilliant thanks mike your a star, I should be able to provide a continuous gap from pitch to pitch and will aim to put an wedge in the starking at the bottom and top of the pitch between each rafter.
  3. Thanks guys, so I just need to wedge the starking open? does this mean i do not require a gap at the ridge and can insulate it fully?
  4. Also just noticed I have posted in the introduce yourself section! so hi i'm Ross - 26 years old and have been consistently renovating my first house since 2016
  5. Hi guys, currently converting my loft conversion - 1965 semi with a cut roof. and I have some questions around the ventilation between the non-breathable felt and foil backed insulation. I have bulked out the current 4x2 rafters with 4x2 and will be filling the void with 150mm celotex PIR and leaving the 50mm ventilation gap. I am wondering whether I will require a ridge vent or will it be sufficient to leave a 50mm continuous gap including under the ridge ridge so the 50mm runs from one side of the rood to the other? I imagine this may be seen a a silly question, but every day is a school day. Thanks in advance
