Our build (4 ears old) is of reasonable airtightness (approx 3.2 in the airtightness test). Our contractor left us in the lurch before completing our 3500sqft home, leaving us to complete it ourselves using 3rd parties. I am trying to improve the overall insulation performance and am being given differing views what's best.
We have GSHP, and MVHR. The contractor advised me that we have a "warm roof" which I understand, and consists of Foil space blanket, over the rafters forming an airtight loft space. My issue is:
Currently we have, 170mm rock wool insulation between the ceiling joists in the loft space which has for the majority then been boarded with chipboard flooring. There is no added insulation between the roof joists (i can see the underside of the space blanket). All the MVHR ducting is exposed in this "warm " loft space and I was told it doesn't need any further duct insulation as it sits in aware loft?
MVHR aside, the main thing is surely the Rockwool in the ceiling joists are counterproductive and is prevent heat rising into the 'warm" loft? I am looking for something assuring of if it is best for me to remove the rock wool from the ceiling joists (which means taking up the boards as well), and putting that insulation (or new insulation) between the roof rafters (180mm of joist depth spare).
Some builders have said " waste of time". just add new rock wool type insulation between the row joists to enhance the space blankets effectiveness, others are telling me exactly the opposite, that my loft won't be as warm as it should be with the ceiling rock wool in place, and my MVHR is suffering as a result. Lastly yet another contractor told us that its fine as it is and we should just insulate the MVHR ducting.
The temp in the loft space in the winter is typically a few 1-2 degrees lower than the rooms below.
Is there a definitive correct answer here as to how I should proceed ?
I have included a pic of the house and its mainly the long single story section I am referring to.
