shbrooks
shbrooks's Achievements
Member
Member (3/5)
0
  1. Thank you for your comments. The overlay UFH is a continuation of the existing UFH in the main house, so seemed sensible to carry it through for continuity and levels.
  2. I have a situation where two bi-folding doors form the corner of my rear extension - one will have a low threshold with the patio, the other (around the corner) will step down to the garden. In order to keep the corner post to a minimum, I would like to set the door frames back, which means they sit over the cavity. I've therefore worked up the following details using Warmotech Phonotherm (RG550) and Marmox Thermoblock to bridge the cavity and would appreciate any comments/feedback.
  3. My builder has installed vent tiles below my dormers, but unless I'm missing something, I'm no sure what they're doing. The roof has a Roofshield Breather Membrane, with counter battens, and a vented ridge so I would assume there's suitable crossflow ventilation across the roof.
  4. Thank you for your comments. Building Control wanted ventilation across the roof so we've raised the roof and installed some eaves ventilators. Better safe than sorry!
  5. I'm currently renovating my property and have two flat cold roof dormers which have been mostly constructed and whilst the cheeks and roofs have been battened out to form a ventilation cavity, there is no actual ventilator to the roof – the contractor is relying on the cheek ventilators which they say will allow air to go up one cheek, across the roof and down the other cheek. Is this commonly accepted or should the roof also be ventilated independently of the cheeks? The cheeks have a 50mm cavity ventilation zone and the entirety of the dormers will be clad in zinc (or aluminium).
  6. Hello I'm converting my loft space and need to redirect an existing SVP due to the new dormers and rooflights, which will all be opening so the vent needs to terminate 900mm above these openings. In order to achieve this, I would need to introduce two sharp turns into the 'dry' part of the stack. There are no new bathrooms, ensuites proposed within the converted loft so the original 'wet' part of the SVP remains unchanged. Unfortunately, I can't take the SVP up the other side of the rooflight as Building Control would not accept any restriction on the headroom in this area. A little unconventional, but if I can achieve this it would be great. Would welcome any thoughts.
  7. Thank you that link was helpful, although it didn't address any of the queries I have currently have, which I can't seem to find answers to.
  8. Hi all. I've laid a fairly deep subbase, say 200mm in 50mm layers, on top of a non woven geotextile membrane down the side of our house between my neighbour and I, and plan to lay porcelain tiles on top in the future. For the time being I wanted to make the area safe as the area had been partially excavated when we had our fence replaced due to our side being 500mm higher than our neighbours (we had to previously excavate a footwide trench to remove the old posts/gravel boards). I plan to take up the rest of our patio which links round, and lay a new subbase for this in the future (existing slabs currently laid on clay ?) I have a few queries having not laid a patio before. Is the compacted subbase a suitable temporary finish or will it degrade over time?..if so, how long can you leave it before adding the tiles on top? Do I need a weed membrane on top of the subbase? I can't imagine weeds will grow between the subbase and the tiles, but would like to know if this does often happen. Do I need to introduce movement joints into the subbase, and/or tiles? Can I lay the subbase in sections? We're altering the house in the future, which will create a larger patio area but I can't lay the subbase for this until we begin the alteration works. If it is possible to lay the subbase is sections, is there anything I need to do to teeth the different sections together? Thanks for reading!
  9. Hi there. Was wondering what type of size of gravel I should be ordering to backfill my ducting trench. I've read that the gravel needs to be "well-graded, free-draining, angular, durable". Would something like this be suitable? https://www.drainagesuperstore.co.uk/product/pea-gravel-shingle-aggregate-1-tonne-dumpy-bag.html Thank you!
  10. Thank you ProDave. I'd rather use ducts I think, so I can get the duct in the ground and pull the cable through at a later, and also add/replace any cables if they become problematic in the future. Any ideas what size SWA cable I need?
  11. Hello all. I'd like to install a number of lights around the perimeter of my medium sized garden to uplight a few trees and shrubs - probably 4 to 5 lights in total. Having recently replaced all of our fences, I currently have a trench I can drop a duct into and install the lighting cables at a later date. I originally thought I could bury a duct and have duct 'T' points which allowed each light to be served by a separate cable. However, I couldn't find a suitable sized duct with 'T' points, the smallest being 110mm, which I found was too large. I'm now planning on running a single cable in a duct, which rises above the surface at each lighting point and into a junction box, which then has a tee-off into each light. The main cable/duct then dips back below the ground until it reaches the next lighting point. Presuming this is possible and a more suitable, what size cables and ducts would I need?
  12. Thanks for your comments. Would gravel/pebbles be solid enough to form a substrate for paving? Excuse my ignorance - I've never done paving!
  13. We recently chose to replace our boundary fence as the concrete posts were leaning badly onto our neighbours side. Our neighbours land is roughly 1 1/2 feet lower than our side so the concrete gravel board was acting as a retaining wall which had actually started bowing and cracking in the centre. I decided to dig out a trench on our side to take the weight off the new gravel boards (now comprising a 150mm concrete board, with two 300mm durapost composite boards with a steel retaining rod) and was planning on shuttering this area and pouring concrete to create a self-supporting concrete strip. I've now having doubts about this approach as I don't want to make this area completely impervious. I'm looking for a solution which won't place load upon the new gravel boards, allows water through, but it solid enough to receive paving. Any thoughts welcome.
  14. Had a look in that socket today and whilst I think I know what I'm doing, I thought it best to check! Do I just remove the black and red wire coming from the transformer, leave everything else in situ and screw the plug back together?
  15. Thanks for all the replies. Incredible response as always. Had a look by consumer unit and found this:
