Photosolo
Everything posted by Photosolo
  1. Hi I’d be interested in any advice /opinions. Ive put this question in the SIPs section too. We are in the process of trying to build our own home. We went with a local company that specialise in SIPs construction. They have finished the basic shell. Walls/1st floor/roof & stud walls are in place. This is where the fun starts! It turns out due to an oversight, the company have fitted the wrong floor. We have joists at 600 centres but only 18mm chipboard floor. Not build regs! (should be 22mm). They have proposed adding a network of noggins throughout the floor system. But as they have used Posi-joists and the current floor is already glued & screwed in place they can only fit L-brackets to support the noggins & not Z-clips. An alternative could be to lay a second layer floor on-top glued & screwed. This will have a knock-on to our floor height with regards to stairs & doorways. Apparently ripping up the original and laying the correct 22mm isn’t an option !? The contract stated 22mm Caberdek
