Good Morning Guys n girls,
	So this is my first post here, and straight in with some questions I’m afraid !
	I’m in the process of purchasing my first residential property at the moment, it’s a semi detached bungalow here in essex, the construction is the perimeter walls are on a deep footing, while the internal ‘slab’ is a separate section of concrete (Not unusual I understand)
	My issue is that the slab has ‘settled’ over time and has been brought back into place using expanded resin injected under the slab.
	 The settling was as much as 30mm in places, and was not level throughout the building. Some parts 30mm some parts just 5 or 6, some none at all.
	The Company who injected the resin offer a 20 year warranty for any faults due to the shrinkage of their material, however that doesn't take too much reading into...
	My issue is this:
		we don’t know why it settled in the first place and how long it will take to settle again (I think it’s a question of when not if?)
		Did the settling cause the DPM to tear or become broken- are we going to get damp issues in the future.
	       C.  We don’t know if the same settling will eventually happen with the rest of the building?
	So the question is this:
	How risky is this.
	How would be the best way to repair it ‘properly’- I assume the only solution is to break up the entire slab and either replace with a new poured floor with deeper support underneath, or with a suspended wooden floor.
	If you were to do this, what would you do to support the supporting spine wall – I guess the spine wall just sits on the slab at the moment, if the slab is broken away, how do we support the spine wall?
	Similarly, when digging the slab out what do we do to support the perimeter walls / foundations of the building
	I’m an engineer by trade and not afraid to get my hands dirty, but just want to know how much would be involved, should the need arise to start digging out the existing slab
	Interested to hear some thoughts an opinions of people who probably know more about this than I do….
	Many Thanks
