Julestools
Everything posted by Julestools
  1. Interesting. What was your proposed IWI build up?
  2. What indeed? I look forward to reaching a well-informed decision. Thanks for all your input so far👍
  3. Making a good decision has become more complicated than I thought, that's for sure! It looks like whether I use 50, 75 or 100mm mineral wool (or indeed hemp or wood fibre), my current estimated U-value of around 0.5 would end up around 0.3 or even less. This is below what is considered safe for a solid wall. However, if I am led by the more optimistic things I've read and been told, I could happily go ahead with my IWI..so long as I take care of room ventilation, airtightness of walls etc. So, although I've been learning a lot, I'm no closer to deciding my iwi design. If only there had been a unanimous 'it'll be fine'. I know a builder or 2 who would have just slapped some celotex on the walls and be done with it! I think, Mike, I will go with option 3, do some more reading and let you know if gets me any closer to the answer I want to hear! Thanks for your replys👍
  4. Ah ok, that's good. We had plenty ventilation, fans going and woodburner chugging away👍
  5. Hi, and thanks! I had read something about the risk of trapped moisture (between the old DPM below the slab and my new DPM above) potentially causing issues with mould, but decided I was over thinking it and as my leveling stuff passed the old polythene sheet taped to the floor test, I've gone ahead and done the floating floor.. almost finished it today, a productive was to spend a rainy Sunday😊
  6. Hi Nick, yes I've levelled the original screeded slab. Since I posted the above, I decided the RonaScreed FastDry stuff had done it's job and went ahead with the floating floor, so there's no going back now! The original slab seemed bone dry, though my gut feeling was to not trust the old thin DPM below. I used a mix as dry as I could get away with for levelling the worst low areas and SBR to bond it. Technically, adding the RonaScreed, it should have been dry enough in 4 days to take 'moisture sensitive floor coverings' so all should be ok. I was just curious about what others thought of the old 'plastic sheet taped to the floor' test. Thanks for the reply👍
  7. Thank you Gus, for a great explanation of the whole insulation, ventilation condensation thing! (I think I'm going to have had enough of these words by the time I finish!) Perhaps I am over thinking.. and here is a good place to do it. Trying to be pragmatic, I'd say that if I moderately insulate with mineral wool (75mm?), ensure good airtightness and ventilation, then it is unlikely that the dewpoint will move to the inside or cause problems given that the inner leaf is already warmer due to the cavity insulation, would you agree? Thanks again.
  8. Yes, I think I am a bit "hybrid" (not hydrid)! 😁
  9. I think I'd use 45x70 with (cork) spacers if using 100mm mineral wool; 45x45 with continuous cork spacers if I opt for a (theoretically safer!) 75mm wool. Feels like I'm splitting hairs now.. It's hard to make a decision!
  10. Brilliant, thanks. I'll look into ventilation options👍
  11. Thanks Mike. The Historic Scotland study is very interesting and offers hope for trouble free IWI for my walls. I'm assuming that I am at less risk of condensation, having an already insulated cavity and therefore a warmer inner leaf? Nor sure if I want to go down the road of modelling the whole building with WUFI. It seems the current U-values of my walls are likely to be around 0.5, so perhaps 75mm mineral wool would be an adequate upgrade. I will look into hemp, and there's also cork boards (no plasterboard needed)... I'm just no so keen on the cost! Thanks again
  12. Hi Gus, no I have a solid concrete floor so no ground floor joists to worry about!
  13. Ah, thanks, ok got it. The cavity is already insulated.. They had some kind of fluff pumped in back in the 90's. I'm looking to improve the walls with internal wall insulation.
  14. ETC, I'm not sure what you mean!??
  15. Mike, I'm thinking of using 100mm mineral wool between studs .. Do you think that is too much, or OK due to the lower risk of condensation due to the walls being cavity, with the cavity already insulated? Also, I had the idea if using 45x45 treated studs/battens with 45mm spacers of some sort every 600mm or so, where the studs are screwed to the wall, giving me a 45mm space behind the studs to fill with insulation, then the regular 100mm batts fitted between the studs. I guess it's a kind of 'warm batten' design, cheaper on timber, but solid enough to fix plasterboard to. I have seen continuous insulating spacer strips used, only 10 or 20mm thick behind the studs ..but I'm wondering if my idea is a daft one, as I've not seen it done quite like that before!
  16. Hi all, I have levelled and flattened my old ground floor screed, ready to take a DPM and a floating floor of PIR and t&g chipboard , mainly using sand and cement with 'RonaScreed fast dry prompt' added, for (hopefully) a more rapid drying. Thickness is from 35-5mm. We're now at day 14 and having taped squares of polythene to it in a couple of places for 48 hours we find no condensation, moisture or darkening of the screed below. The plastic sheet test, from what I can gather, is only a rough indicator of dryness and more accurate tests should be used before laying final floor coverings like wood laminate or tiles, but would I be right in thinking that when laying the DPM, PIR etc over the screed, moisture content (and more accurate testing) would be less critical, and therefore the plastic sheet method will do in this situation? I'd be very grateful for any guidance on this. Many thanks.
  17. Thanks Mike for a very helpful reply. Yes, this is part of an extensive refurb, including a roof upgrade later this year, and floor levelling and insulating currently underway. I am confident about the air tightness of the walls so currently not seeing a need to remove the plaster, but perhaps a condensation risk assessment may be a good idea, as Redbeard suggests. Breathable paint, no probs! Thanks again👍
  18. Good point.. And yes I might be overyhinking it! We're they using vcl to keep moist air out, or somehow making it breathable I wonder?
  19. Insulated stud sounds good, though someone suggested spacers at intervals to bring the studs away from the wall to minimise bridging. Then wool can go behind and between studs too. Intello is clever indeed! Would you regard pb with, say, the more porous 'one coat' plaster on it, breathable enough, or not?!
  20. Thanks Redbeard. So would using Intello increase the chances of a dry healthy wall and insulation space if using not-so-breathable plasterboard and plaster?
  21. Hi all, I want to add internal wall insulation to my 1970's block cavity walls. The cavities were filled with a mineral wool type fluff in the 90's, which appears to be dry where I've been able to see it and there is no evidence of damp or mould in or on the walls. The external render is also in good shape. We are leaning toward a stud frame fixed to the inside of the external cavity walls with mineral wool bats like knauf RWA45 or RS45, with plasterboard over. Our reasons being, it's cheaper than using celotex or insulated plasterboard, it's a breathable option which, from what I gather, would carry less risk of issues with condensation and mould and we don't mind losing a bit of internal space. I'd love to hear your thoughts and knowledge on this approach to internallly insulating cavity walls. Is it a good idea to do it at all? Is a vapour-open breathable approach better, or should I use a vapour barrier, as some manufacturers suggest? Any and all thoughts welcomed! Cheers, Jules
  22. OK, if it'll do no harm with the old dpm also present below the slab. Thanks.
  23. Thanks for the reply Jimbo. Yes, taped pir will do that, but I was talking about the dpm under the slab. Kingspan and others spec a dpm laid over the slab, before the pir goes down, which may be pointless if the old dpm seems effective despite it's age. I was just wondering if should trust the old dpm or not, or lay a new one over the slab anyway, just to be on the safe side. Cheers.
  24. Hi everyone, I'm just starting to renovate our new home, a funny old bungalow built in 1973 which has an uninsulated concrete floor. After a bit of sds poking around in a few places I can confirm a dpm is present under the slab, it's clear and looks like 1000g.. definitely not 1200g, it turns up where the slab meets walls and ends in the vicinity of the bitumous dpc, but is not lapped/connected to it. Despite the fact that the dpm thickness and it's installation isn't ideal, the floor seems really dry, with no signs of past or present damp or mould. I taped a big square of polythene to the concrete in a couple of spots for a couple of days; there was no sign at all of any moisture/condensation or damp. After some levelling of the screed, I'll be fitting a floating floor with pir boards, taped, with 22mm chipboard t&g flooring on top. The question is.. Can I trust that old dpm?.. given that the floor seems very dry, or should I lay a new 1200g dpm over the screed to be on the safe side before the Insulation goes on?... Also, if the old dpm is still effective, as it seem to be, could a second dpm over the slab cause issues, given that the slab would then be vapour-closed on both sides? Oh what joy it is to be an indecisive over-thinker😂 I'm really looking forward to hearing people's thoughts on this one. Thank you.
