From_a_different_time
Everything posted by From_a_different_time
  1. Thank you. Never having had any building work done before now, I wasn’t sure if it was one of those situations where - faced with two options - one was clearly preferable to the other. From our recent discussions, Severn T would, I believe, prefer a build over but also seem willing to consider a re-direct if that’s the only realistic option open to the property owner.
  2. Currently waiting for a revised quote from the builder to confirm. But in the meantime, just trying to understand how high the potential risks are when building over (sewer blockage, pipe failure, etc).
  3. Thank you for the reply. As far as we can see the major downside with building over the pipe is that with the clearance required from the edge of the new foundations, we’ll need the outer wall to be about 3.75/3.8m out from the rear wall of the house. This is larger than we ideally want and the build cost will be far more than the initial quote we had from the builder which was for the outer wall of the extension to be 2.9m out from the house. It’s only after receiving the initial quote that the potential issue with the sewer became apparent. Of course, if we build over the existing pipe - and assuming the CCTV survey is clear and the pipe doesn’t need replacing - then one benefit of this is that we wouldn’t run the risk of something going wrong and upsetting/causing grief, to our neighbours (drainage-wise). No manhole located within the footprint of the new extension.
  4. Thanks. We’re on a small estate. The sewer in our garden connects just 3 properties and we’re the middle one.
  5. To make the room useable, our ideal distance (outer wall) 2.9/3.0m from rear wall of house.
  6. Afternoon all from a new member. Looking to commission a small single storey extension on the back of a 1960s house. Technically, within Permitted Development. This is the first time we’ve ever contemplated doing anything major to any house we’ve owned, so experience and naivety are polar opposites! We have a sewer (adopted by the water company, so public) crossing to the rear of the house. On a slight angle; 3m out on one side, 2.6m out from the house on the other. Pipe size 100mm. The question is simple but I bet the answers won’t be! There is a choice to be made; is it common sense/the preferred option, for us to leave the sewer pipe where it is and build over (with approval) or should we be looking to do everything we can to have the sewer re-routed so that it doesn’t sit under the new extension? Whatever we choose to do will have a significant impact on the size of the extension - hence cost. We’ve been in touch with the water company who have been helpful. The builder seems to prefer to move the sewer. Just trying to understand the advantages/disadvantages of each. Thanks for any input. Much appreciated. Happy to provide more info if it helps.
  7. Banking in my former life. DIY - I’ll have a go at most things. Gloucestershire. Bob
  8. Thanks. What did I do - as in previous jobs? Re skills - anything or specifically related to DIY etc? Happy to share. Bob
  9. Just introducing myself as a new member. Retired now and basically a DIY-er looking for some guidance on issues re potential new single storey extension. Hope at some stage I might also have something to contribute to the forum. Thanks. Bob
