Jacko994
Personal Information
  • Location
    Windsor
Jacko994's Achievements
New Member
New Member (2/5)
0
  1. Thanks for your advice guys. The extension is just getting boarded and skimmed at the moment so once that’s done I’m going to knock those 3 courses out and start prepping the floor. my architect spec’d 25mm perimeter insulation to go around the edges, would this suffice to absorb the expansion in the screed with UFH or would you recommend the insulation foam around the wall edges as well?
  2. Thanks Nick. what about the dpc that is running across the inner course? Also that inner course is 3 courses high at the moment, above the block and beam. Are you saying to remove all 3 courses, or just the top 1 or 2? Thanks
  3. Good evening everyone, I wonder if I can get some help/thoughts on the below - I’m currently in the middle of managing an extension/renovation on our property and I’m trying to get some clarification on how to finish off the cavities at the front and rear openings and tie in the screed. At the rear where we’re going to be having bifolds with a level threshold, I have filled with some celotex insulation. I was going to finish it with a cavity closer but the company installing the bifolds want to knock the course of bricks on the outer skin off to place the bifolds on. Is this normal practice? It would then mean I can’t use a cavity closer so what would be the best way to close the cavity up ready for screeding? Any suggestions would be much appreciated. Thanks, Jack
