OVIP
Everything posted by OVIP
  1. Yes the pergola will rest on 4 vertical posts. I am not sure about putting the fixings in the mortar though, as I recently repositioned a down pipe and the mortar between bricks or whatever compound they have used, did not look very strong.
  2. Hi All, Will it be ok to attach a timber ledger (6x2) on the lintel area above the patio doors? This would be for a lean to pergola (4.5m x 3m) The ledger was supposed to be installed where the yellow line is in the attached pic, and it should need about 3-4 masonry screws for fixing on the lintel area. I have read some post saying it could damage the house structure and posting this as I am concerned… Are lintels steel inserts like the one in the 2nd picture attached? The house was built in 2020 Eventually the ledger could be installed higher but I was hopping could attach it here as it would be the same height as the side house existent pergola. Thank you!
  3. I am not sure I understand how to use the potential scaffolding planks. For reference the pergola roof is about 2.5m wide down the slope and about 9m long. The space between the lower end and the fence is minimal, or less than minimal, about 20cm, just about allowing me to instal and remove the gutter and potentially hammer the poly sheets up with a mallet.The only access to the roof is on the sides unfortunately. any chance you can sketch a drawing of your support model using the scaffolds? If I am not asking to much? I am sorry maybe I am thick or something, but I did not understand how it could be done..
  4. Yes thats how they been installed and the sizes of glazing bars/ poly sheets matched. What I think happened is that the poly sheets might have been cut a little bit too narrow and there was not a lot of material left to be secured by the glazing bars or the glazing bar plastic top has not been banged properly into place.
  5. Hello, yes the flash band is damaged and probably a bit scorched or peeled of on other areas (not only on top of the the 2 poly sheets sliding down)...Regarding using scaffold planks across the roof, I feel that it will not be quite safe as in, walking on them could crack the glazing bars (maybe I am wrong) plus I feel that the scaffold planks could easily slide down the roof with me on top of them... I was thinking to install timber (100x47) (like the ones in pic 4) between the rafters and about 50cm away from the wall, that should be enough to support my weight I hope and to prevent the ploy sheets from snapping. Regarding the lead flashing, that would be ideal of course but it will be a hard job to do climbed on the poly sheets without proper support and concerned about snapping the sheets or falling
  6. Hi All, I had a lean to house made 3yrs ago, and now 2 of the 9 polycarbonate panels began to slide about 1 inch each, dragging the flashing tape with it…. I assume the panels should have been secured on the joists when installed but they were not. The panels are about 90cm wide and 2.5m long. Our cat has also been climbing on the roof for a year or so by now, so I guess that had an impact as well. Is there a way to push these back and to replace/fix the flashing tape without removing all panels one by one? I was thinking that if I would install some supporting joists between the rafters, 40-50 cm from the wall, maybe I could climb and walk on them and that way could get to the damaged flashing tape and sort it. With the polycarbonate panels I was thinking to remove the gutter and the end stop bars at the end and hammer it up with a mallet. Would it go through the glazing bars? Is this a doable thing or I am lying myself and what I need to do is actually take everything apart..
