I like floors
Everything posted by I like floors
  1. Hi, I'm facing the exact same problem. What did you do in the end? Cheers
  2. Thanks for the replies. I'm not able to fit anything below or above the joists due to the floor type being set (already bought) I can only really choose what to put in the 7" void. Redbeard, if i just stuffed the void with RWA45, would you be concerned about it sitting directly on the asbestos boards? Would stopping all air movement around the joists be a problem in terms of rot?
  3. I should add that removing the asbestos cement board from below and re-fixing using resilient bars or similar isn't practical (due to height and asbestos) I should also add that I've already bought the chipboard for the floor (it's Torfloor2 plus) I realise that this will never be great acoustically. My first idea is to use 100mm PIR plus 25mm acoustic roll (knauff or similar)
  4. Hi all. I'm currently renovating a late 60's terrace with a bedroom suspended above a driveway (which provides vehicle access to the garages behind the terrace) The floor of this suspended bedroom is made up of 7" joists at 16" centres. Directly fixed (screws) to the underside of the joists, is some sort of cement board which more than likely contains asbestos. To the top of the joists will be glued and screwed a 22mm chipboard floor (with UFH grooves) and a corresponding cement board is screwed on top of the chipboard. Final floor will be glued LVT. There has been no provision for ventilation of this floor void (other than a non tight fitment of the asbestos boards) There is a no sign of rot or dampness in the joists (although there has been some woodworm) I'd appreciate some opinions on how to best insulate this floor both thermally and acoustically.
