joannaerck
joannaerck's Achievements
New Member
New Member (2/5)
0
  1. I had internal wall insulation installed through my energy supplier, funded by a government scheme. I have an Edwardian semi detached house. The system they use is called Ezy Fit (https://www.ezy-fit.co.uk/shop/systems/m-iwi-internal-wall-insulation). The insulation is predominantly made up of 4" thick high density slabs of mineral wool (or on the reveals, Jackoboard) installed directly onto the wall and mechanically fixed into the brick. Then the usual plasterboard and plaster skim. I was really unhappy with the finish. Almost every wall was out of plumb, not level or not square, far more than tolerance. This was glaringly obvious around the windows and sills where the wall bowed and everything looked completely crooked. I asked for an inspection and the energy supplier agreed it was unacceptable. Builders came back and started removing some of what they'd done, and discovered that, in the month or less since finishing, there was mould all over the walls. They ended up taking everything off which was obviously a huge waste and a massive disruption, because almost the entirety of the walls underneath had developed damp where there was none before. They admitted to a poor and faulty installation causing the insulation to sweat. This system works by eliminating air gaps, so preparing an even surface, free of missing plaster or holes, is vital. Every potential air gap, such as around the screws should be sealed. However in my case, they hadn't even, for example, taken picture hooks off the wall. The energy supplier used to install the more common SWIP system using wood battens, a vapour barrier and leaving a deliberate air gap, which also allows for a flat and level finish. They no longer use this system (only because the use of wood lowers the fire rating slightly). They wont offer any alternative insulating measures. My options are to either: - have it installed again, with more oversight and checks on the work. (It'll be different individuals on the job, but part of the same team). - have my house returned to how it was. They'll leave a new plaster finish and I get a voucher to go towards redecorating. However I am worried this insulation just isn't the most appropriate for my property. The old walls require careful preparation for effective installation of this insulation. Undulations and bowing in the walls can't be eliminated. I'm concerned about the quality of the workmanship. I can't be sure there won't be gaps and damp isn't forming again. Is there an effective way of monitoring the insulation for damp, without removing part of it and indefinitely putting off redecorating? If I choose to have it returned to how it was then obviously I do not benefit from any insulation after all of this disruption. Regarding potential compensation, so far I've only been offered £200 for redecorating. Any advice is much appreciated!
