ex-70s-GP-surgery
Personal Information
  • Location
    Perthshire
ex-70s-GP-surgery's Achievements
New Member
New Member (2/5)
0
  1. Hi SteamyTea, Yes EWI is what I have on my planning permission. I'm just learning how this forum works and put a separate post in "Heat Insulation". As a thread it hasn't run very hot yet. Building envelope with EWI and upgraded warm roof - drying out I have some walls with sections of IWI so I've to consider them. I've read about ideally keeping to one third R-value inside to two thirds outside for avoidance of interstitial condensation. I'm thinking a 70mm rockwool batten in the 100mm stud and 120mm EPS EWI system. Where I open the walls I would put back a vapour open VCL so things can dry to the inside. I think I'll just be slowing vapour and air movement as a retrofit isn't going to get to everything.
  2. I've been through all the details of the buildings construction and poked holes/cameras into most voids to understand everything. I've not found any stash of white powder asbestos or otherwise, but am collecting plasterboard dust on my paintings.
  3. This is my second home and like my first needs some work. I see potential but it needs an insulation upgrade/some insulation and a creative facelift. The building is a dated 1970's built ex- GP Surgery in a small Scottish town. I'm an artist (of the artwork painter variety😜 and plan to create a home gallery exhibiting my works. Unfortunately planning wouldn't allow a shed in front of the façade, so they now have a yard of stockpiled building materials that I can't tuck away and inside is also cluttered with materials that I'm trying to keep dry. It doesn't feel much like a gallery yet apart from there being paintings all over the walls! At the end of a couple of tough months the wood burner was commissioned. Now it is in regular use, but when it dies down the heat doesn't last. Time is ticking and I want to firm up on an insulation strategy so I can submit to building control. I've approached 9 builders and had 2 visit the site. I think I've a team on board, but am worried I'll loose them if I can't line up a start date.
  4. Hi all I've been reading on here for 18months, but yet to get underway with my retro-fit upgrade. There has been a lot to get my head round. I love perceptual reasoning, but it gets stressful where I might be paying the price of getting it wrong. My building is a 1970s built ex GP surgery. Most is a 100mm stud wall timber frame covered poorly by 20mm of polystyrene then 100mm split-faced dense concrete. In this 70's build the 20mm of non foil-faced sheet polystyrene is where a cavity would usually be. There is no insulation in the 100mm timber stud. There wasn't much thought to insulation! The 70's era sections have no weep holes or any kind of ventilation. My existing roof is a flat warm flat roof with 60mm of insulation. The fascia/soffits are empty with no insulation link to the roof insulation. As I'm in Scotland thoughts have been to do 100-120mm of eps EWI system. Could I add a minimum amount of insulation to the existing empty timber stud and at same time use membrane on studs to limit moisture ingress? I don't want to trap any moisture in there that finds a way in through poor airtightness of the inner skin. I would take off the existing timber fascia and soffits and link the top of the EWI up to the roof deck. (Good depth with layers of PIR back filled with foam to protect rafter ends) The roof will also eventually get 100-120mm of extra insulation build up. Ok so I'll have an envelope with much improved airtightness. In a retro fit I think that internally it would be nigh impossible to create an airtight seal without wrecking the rooms. Will the thickness of the EWI mostly protect the inside from low temperatures and condensation? I've spoken to one EWI installer who wanted to put trickle vents all over the outside just to be sure. Sounds like an expensive cosmetic render? Rooms are generally 55%RH and I have a dehumidifier for washing. I'm thinking (bathrooms) 2 X humidity regulated fans and if sensible some heat recovery ventilation as the airtightness increases. The second wall in my attachment is a different makeup. It is currently a partial fill cavity. I looked at filling the remaining half of the cavity and a woodfibre EWI system or just EPS EWI. There is currently 70mm of PIR IWI on a section, but that could be removed if it makes interstitial condensation more likely.
