SteveTheRepairman
Personal Information
  • Location
    Leatherhead, Surrey
SteveTheRepairman's Achievements
New Member
New Member (2/5)
3
  1. Glad you found a solution. That information could also help a lot of others. The units are made in China and some components are of dubious quality. Heat definitely accelerates the aging process of the components but they will ALL fail eventually. If you would want me to repair and upgrade your PCB to use quality longer life components then it would work out to be slightly more expensive than the Heatmiser new unit (with their shipping). I charge £10 to repair and upgrade the board (unless it’s a complete gonna!) plus postage of £3.25 to return it. Of course you would need to post to me so it’s about £16.50 in all. Shame you are not local as that would save all the postage costs.
  2. Sorry, I don’t know the answer to your question but I see someone posted the same on the Heatmiser forum and was told they are not compatible. I am amazed that HM only charge £10 for it. I don’t think I could buy all the parts for that! I can only assume they have an unreliability issue with them and want to keep their customers base happy by offering a relatively cheap fix. i see you are in Suffolk which is too far away for you to drop in (I’m in Surrey) otherwise I could have offered you a cheap repair service. I effectively re manufacture them replacing as a matter of course the components that age with higher endurance, higher spec ones that should last a lot longer.
  3. I have now repaired a lot of the V1 back panels including Pyewacket’s who posted above. One thing that is common is that as they start to fail, the linear regulator on the PCB starts to dissipate more power as the pre regulator voltage increases considerably. This generates more heat that will cause even more misreading of the actual room temperature. If you experience increased positive inaccuracy of temperature it is likely your back panel is on its last legs. Eventually the linear regulator also fails due to overheating like it did on Pyewackets PSU. Hope this may be of help to anyone.
  4. I am based near Leatherhead in Surrey, about 10 mins from the M25 J9 or J10.
  5. By chance I stumbled across this thread and found it very interesting. By accident I have been repairing the back panel PSU of Heatmiser neostat V1’s now for several months. The background for this is that I built a large Scandia Hus property in 2011 with UFH on three floors. I fitted 24 x 12v networked Heatmiser PRTN style touch thermostats, touch pad and a net monitor to connect to the internet. This actually worked quite well until recently where the Heatmiser app is now just about useless on the iPhone latest IOS. So I looked at changing over to neostats with a neohub but there is no direct replacement for all the thermostat types that I have. In addition, the neostats look like a backward step in both aesthetics and function to the touch screen stats. I purchased a neohub and some cheap faulty neostats from eBay (which I repaired) to investigate the Neo app and whether I could fake my existing system with HW/SW to operate with it. Unfortunately this turned out to be near impossible due to encryption of data packets using SSL and Heatmiser would not help me. However, from my experience with the neostats, I do have a clear understanding of the PSU design and why it fails. I have repaired quite a few now but use much higher spec parts than the parts that Heatmiser have assembled them with. The repaired PSU should last a lot longer than the original. If anyone wants their backplate repaired then I may be able to offer that service at a small cost if that sort of thing is allowed on this forum. I am now investigating a HW/SW solution to allow my legacy netmon based system to be used under Apple HomeKit via a home hub and hope to make good progress with that very soon.
