NewbieJ
Everything posted by NewbieJ
  1. Thanks John, I switch to winter mode, so the cooling mode in theory if working correctly, it should not kick in. All very strange.
  2. I have switched it to Winter mode, but I am wondering if it is stuck at summer mode.
  3. Thanks Nick. Yes, there is 3 sets of fan, the first one is the usual mode. the other 2 are boost mode. One is connect to the bathroom, and the 3rd one is in the kitchen. There is a thermostat at the wall that is connect to it, which has a Summer mode and Winter mode that can be switched on and off. My understanding is that when Summer mode is on, the cooling will kick in when the temperature reach the set point. On the other hand, if the Winter mode is selected, this will switch on the heat recovery mode. Please find the user guide and installation manual below for your information. MRXBOXAB-ECO5-AECV.pdf MRXBOX-ECO5-AECV User Guide.pdf
  4. Thanks for the explanation! Yes, I am clueless on this.
  5. Inside of the cover it has 6 dials which adjust the speed at which the fans rotate.
  6. Hi Nick, No not I am aware of. In fact, I thought that the incoming air is actually rather cold. It is more like the cooling mode is running, but I actually have it switched off, therefore I am not sure if there is something wrong or not.
  7. Hi all, I was wondering if someone would be able to advise if something is wrong with the MVHR in my one bed flat. I recently moved into a new build flat that has the Hybrid system MRXBOXAB-ECO5-AE(OH)CV installed. I have noticed that the amount the electricity that required to run the MVHR seems to be extremely high. At first, I did not know what the cause of my high energy bill was, however after getting the smart meter display, I can now clearly see that the MVHR using around 550W just to run it. I would be grateful if anyone would be able to advise if it is normal? And if I have missed something. Thank you in advance.
  8. Thank you Jack and JohnMo
  9. Hi All I have recently moved in to a new build flat that has a Nuaire MVHR installed, however, I am not sure it is working as it should be at the moment. I joined the forum and hoping people here would be able to advise if the system I have is working correctly.
