Jan_Kropf
Everything posted by Jan_Kropf
  1. Hi all, We are currently refurbishing our house in Oxford. We have a suspended floor with a concrete foundation under it. We want to insulate the floor and install UFH, however the ceilings are farily low meaning that I would want to avoid height build up of the floor as much as possible. I lifted one floorboard and measured. The joists are 80mm, there is another 80mm space below it. Initially I had planned to install the insulation described here: https://www.ecologicalbuildingsystems.com/post/best-practice-approach-insulating-suspended-timber-floors Using this approach, I would be able to add 80mm of insulation and there would be 80 mm of ventilation space remaining. Is this enough space for that plan to work? Both in regards to insulation for UFH and to the ventilation space below. If not, what other possible solutions are there? Would an insulated concrete floor make sense? If yes, how costly is that in comparison to the solution above? On a separate note, we would also like to install UFH on the first floor. (I read a lot about UFH vs radiators vs nothing at all on the first floor. We currently think that we don't want radiators for aesthetic and space reasons and would like to avoid the possibilty that it gets cold there in winter.) What kind of insulation would you install between the floors then? (We currently have 200mm space in that ceiling, but we need some of the space for plumbing, electricity and MVHR tubing.) Many thanks, Jan Here the link to the introduction of our house in case you need more information.
  2. Thanks everyone for the input already. Here a short update from our side: We now have the keys and could do a few investigations. We were very pleased to hear that there is no asbestos inside the house, only the soffits have asbestos and they are supposedly in a good state with no immediate action necessary. Concerning the timeline: We will be in my wife's homecountry for 12 weeks (we're expecting a daughther, family support is very much appreciated here). A good friend of ours is an architect. He is helping us with the planning and will oversee the works while we are away. Once we are back (mid June), we can move into a friend's place for a while. We hope to finish the works by end of July and move in then. We have accomodation sorted unti mid August. Here the list from my first post and the individual updates. I added numbers to make it easier to reply. 1. general refurbishment, investigate wiring and plumbing, replace if necessary --> Our architect and his building crew (including electrician and plumber) are ready for this. 2. build a downstairs cloakroom (at the moment there is only a bathroom in the first floor) --> Same as above. 3. insulate the floor and loft --> The loft is surprisingly well insulated already, we will potentially upgrade later this year. The floor is a different issue, I will ask in the relevant subfolder. 4. replace windows with new double glazed windows, replace the front door --> We found a window installer that did great work at a friend's place. Their quote is also reasonable, even a bit cheaper than the quotes from the big companies. And they were more knowledgeable than other window installers we talked to. 5. change the heating system from electric heaters to ASHP (the house is not connected to gas at the moment) --> We talked with a heatpump installer, obtained quotes and checked whether it would work in the house. It seems all fine besides the location of the heatpump. We would have an ideal spot for it, however it's closer to the boundary of the property than 1m.... Supposedly the law will change this year (as soon as parliament finds time to discuss this). Does anyone have a closer insight into this? 6. investigate the wall (supposedly filled cavity wall), potentially upgrade filling --> it is filled. We don't know how well. Investigating and maybe upgrading this is planned for the future. 7. install MVHR system --> Our builder has one in his home and is very happy with it. We are happy for him to install one, especially as the new windows will require either a ventilation system or trickle vents (We don't want those, for both draft and aesthetic reasons). I will open a separate thread for this. 8. install underfloor heating -->We plan to install a wunda rapid response system, mostly DIY. 9. put in click LVT panels in the whole house, tiles in the bathroom --> Planned for July, we have already a good idea what we want. At the moment, I would rather use a glue system instead of a click system as there is less height build up and individual tiles are potentially easier to replace. 10. install kitchen and bathroom --> Planned for July, we have already a good idea what we want. 11. plaster and paint --> Once everything else is done. Looking forward to your input! Again, please let me know if something sounds really stupid.
  3. Hi all, We are just about to complete the purchase of a 2 story 3 bedroom semi-detached house in Oxford. It was built in 1961 and owned by the same owners since there. It needs quite a lot of work. We plan to use a combination of contractors and DIY. Here our plan in short, more or less in the correct temporal order (This is of course just the overview, I will ask detailed questions in the relevant forums.): - general refurbishment, investigate wiring and plumbing, replace if necessary - build a downstairs cloakroom (at the moment there is only a bathroom in the first floor) - insulate the floor and loft - replace windows with new double glazed windows, replace the front door - change the heating system from electric heaters to ASHP (the house is not connected to gas at the moment) - insulate floor and attic - investigate the wall (supposedly filled cavity wall), potentially upgrade filling - install MVHR system - install underfloor heating - put in click LVT panels in the whole house, tiles in the bathroom - install kitchen and bathroom - plaster and paint As I said, I will ask all detailed questions in the subforums, but please let me know if some part of the plan souns stupid. We may install solar panels at some point, but we have to be considerate about the budget here... I attached two pictures of the house. Thanks a lot for everyone posting here, I already read a lot of valuable advice!
