Rosslyn
2 Followers
Personal Information
  • About Me
    Retired since 2019 and now looking to build my dream Eco retirement house.
  • Location
    Wallingford, Oxfordshire
Rosslyn's Achievements
Member
Member (3/5)
6
  1. It went very successfully for me with a 250mm raft foundation onto 200mm Greenraft XPS insulation. Quite a lot of excavation (750mm O/A) and then compacted Type 1 hardcore. Came in about £40k so below my budget which is almost a first! Certainly a vast improvement on the deep piling that everyone seemed to advise was inevitable.
  2. Can I ask how the costs went with the insulated raft foundation? I am presently looking at Greenraft but compacted Type 1 has to go 750mm below ground level so a lot of clay to be removed from site.
  3. Yes it does get too high some Winters. Drainage into any ditch is a no no and can't even do so for rainwater. The peercolation test already excludes regular soakaway and suggested use of Swales.
  4. It's just a bridleway with residents vehicle access (3 houses!)
  5. A septic tank would be tempting as that is what's there now. I'm on one at my present house and the problem is that the water table gets very high over a wet winter and I think would be problematic.
  6. Thames Water point you towards their approved contractor for new spur connection I need (in bridleway). But there also looks to be an option to have another contractor carry out the work subject to their approval and inspection. A nearby property spent £14k for 5m connection so hoping to avoid! https://www.thameswater.co.uk/help/home-improvements/how-to-connect-to-a-sewer Has anyone gone through this process successfully?
  7. Thanks I will definitely group as many together as I can and yes £298 was the rate.
  8. I am demolishing a bungalow to build a new single home for myself. I have applied to discharge the Tree Protection Plan and paid SODC £86.00. A couple of days later I was told the fee should be £298. After calling and discussing with the planning dept. they seemed to also think £86 was the correct figure. But I have just been advised; "The correct fee is £298 as the original application is for a dwelling rather than an extension to an existing dwelling" Can I check what others in similar builds have paid to discharge conditions as I have a good number to go!
  9. From this part; Mechanical Demolition: Equipment: Identify the type of equipment to be used (e.g., excavator, demolition hammer, etc.). Technique: Describe the demolition method, including whether it will be top-down or bottom-up, and how the structure will be taken down. Control Measures: Outline measures to prevent premature collapse or the collapse of adjacent buildings, including the use of temporary supports and safety barriers. Debris Management: Debris Zones: Identify designated areas for storing debris and outline how debris will be removed from the site. Removal: Describe how debris will be loaded and transported to the disposal site, ensuring safe handling and preventing dust and debris from escaping. V. Safety Procedures Personal Protective Equipment (PPE): Specify the required PPE for all personnel on site, including hard hats, safety glasses, gloves, and high-visibility clothing. Training: Ensure all personnel are adequately trained in safe demolition practices and the use of equipment. Emergency Procedures: Outline emergency procedures, including first aid, fire safety, and evacuation procedures. Exclusion Zones: Establish and clearly mark exclusion zones around the demolition area to prevent unauthorized access. Hard-Hat Areas: Identify hard-hat areas and ensure they are clearly marked. Noise Control: Implement measures to control noise levels, such as using noise barriers and ear protection.
  10. I have prepared one in part but am struggling to complete. Does anyone have one I can use to help me finish and get the demolition notice submitted? Thanks for any help.
  11. It's described as 1.5 floors but just over 8m high so lots of room upstairs. Lovely big plot so much better house for the location.
  12. Using Danwood so SIP construction that should take 6-8wks on site.
  13. No it's not Stones field but a lot of these bungalows are very similar. No time to lose!
  14. SODC delayed the planning decision by requesting a Bat survey that had already been submitted, rather odd. I have had positive support so far and didn't want my programme to slip 🤞
  15. Good to see your finished house and looking forward to getting there this year. I am just about to sign the contract with Danwood. I had a shock getting a quote from one of their recommended foundation companies. It came in at £66k! I'm hoping to get a much improved cost from a local company even though they have not worked on a Danwood project previously. My next step is to get the Geotechnical survey as clay and tree roots may mean I have to go for deep pile. Still trying to find a structural engineer and then to appoint the foundation designer. Welcome any advice from others experiences.
