BallyT
Everything posted by BallyT
  1. Thanks Russell, that's helpful. The flat roof is finished unfortunately, but the ceiling isn't in yet. So I'll do the following: Spray insulation into the webs. This will also close up the cavity (is that enough to stop the cold?). Box the beams off internally with PIR or Aerogel. Finally, wrap the whole lot with fire proofing.
  2. Hi all - first time poster here and hoping I can get some help. My house is currently under construction, I have no building experience whatsoever but I'm now starting to think we have some issues. We have a single storey, with a warm flat roof that adjoins a two storey block which is supported by 2 steel beams - 1 for the outer leaf and 1 for the inner leaf and concrete slab between ground floor and first floor. I've roughly drawn what I believe our detail to be below. Since we poured the screed flooring about 6 weeks ago we have had water pooling under the airtightness membrane near the steel. Obviously this is caused by condensation. My engineer is saying this will subside once the floor fully dries out. I have 2 concerns: I'm pretty sure with the way it's built we will always have a terrible cold bridge on the beam supporting the outer leaf? Is there anyway to remedy this at this stage to ensure we minimise the risk of condensation going forward? Is the warm roof build up correct? From researching myself, I see there should be a vapour control layer inserted directly below the insulation. The engineer is telling me the airtightness membrane further down serves the same purpose - but I'm not so sure. Any advice would be much appreciated. Particularly on the actions we can take now to make the best of a bad situation (if my concerns outlined above prove to be valid). Thank you.
