Gringo
Gringo's Achievements
New Member
New Member (2/5)
0
  1. Silone would stick it down OK but wouldn't be very effective to allow levelling. Stone resin tray's must also fully supported underneath or they will crack.
  2. Was that a stone resin tray or fibre glass? Stone resin is much heavier compared to FG.
  3. Unfortunately it's a black, slate effect tray which "she who must be obeyed" picked. All manufacturer's generally recommend a weak concrete mix bed & have done for the last 20 years or so but, as I said, I've found this less than ideal. I'm thinking that, with the modern building materials now available, there must be a better option. I thought about using expanding foam but wondered if it was strong enough to carry the weight of our new, 120cm x 80cm stone resin tray tray which weighs in at about 30kg! After all the problems I've had with the last "tradesman's" efforts on DPM & plumbing, the very last I want is to have to pull it all up again!
  4. Having moved to our bungalow around 3 years ago, I'm having to replace our ensuite shower tray due to damp issues. I decided to gut the whole room & start again & I've dug up most of the subfloor under the tray & found that the idiot who installed it 10 years ago just cut through & dug up the original DMP & didn't replace it with anything! This left the whole area under the tray exposed to damp ingress from the subsoil & moisture creeping through under the DPC in the external wall, the internal wall above the DPC was also extremely damp. This is obviously what was causing the smell & things going rusty which first made me aware there was obviously a problem. I've dug up most of the subfloor under the tray to let it dry out & will be reinstating a new DPM, connecting this to the wall external DPC before installing new drainage & a new stone resin tray. I've done this before a couple of times in the distant past but found bedding on a weak mix concrete, as per most tray manufacturers standard instructions, less than ideal TBH. I'm generally experienced in all aspects of building work including dry lining, plastering & tiling etc. & wondered if anyone can offer opinions/experience on bedding the new tray on either drywall adhesive or a waterproof tile adhesive as an alternative.
