I thank you both for the advice and recommendation.
I had read the various recommendations that said to avoid that duct however the design needs a branched system and the branch will be mainly running behind an ashlar wall. I have designed the system including static pressure loss, flow rates and air speeds. The critical run pressure loss is around 30-40Pa, with the main variation being on which valves are used. Flow rates have been kept low. I originally agonised over the choice of duct, but I am now satisfied with the choice.
By all means, use me as an experiment and I will report back as to how the system has fared when completed.
Given that I will be using the 125mm ducting into 125mm valves, does anyone have any recommendations that are a better solution than the Unifllex+ with the collar?
(Always aware that it is hard to convey tone in written text: please read this in the best way possible 🙂 )
