Fairy
Fairy's Achievements
New Member
New Member (2/5)
0
  1. thanks @Iceverge would this metal sheeting be better than epdm only or all the other options there too? (traditional 3 layer felt roof/ fibre cement slate tiles / profile 6 fibre sheets)
  2. thanks @joe90so to confirm there is no issue with raising the pitch higher than the neighbours garage? no comeback etc?
  3. oh yes he also said it would make it higher than my neighbours garage next to mine so cant do that?
  4. thanks @joe90 is that expensive to do?
  5. thanks @Iceverge i spoke to the builder and he said these sheets cannot be used as my pitch is below 11 and apparent need 17 degree minimum to doa. roof like that - i have no idea what this means, does it make sense to you? if yes what else would you advise please?
  6. thanks @iceverge how long would insulated metal sheeting last and is that any of the options i listed above or something totally different? and it's suitable to then have a room built in there then with metal sheets?
  7. it's not letting me upload the video i took internally so heres a screenshot of part of it internally
  8. this is the garage
  9. Hi all, ive moved into a new house and found the garage roof is leaking, so i've got quotes to get this repaired, turns out the previous owner has been doing patch up jobs for a long time AND its an asbestos roof so need to replace the whole thing. I want to later on down the line convert the garage into a usable room one day. So want to do this correctly. I'm wondering if anybody can recommend which would be the best option for the new roof, while still being cost savvy of course, as each builder is of course saying the one they want to install is better than the other options lol The options are: traditional 3 layer felt roof epdm rubber fibre cement slate tiles profile 6 fibre sheets It's a slightly slanted roof if that helps.
