Sam B
Everything posted by Sam B
  1. What's on the other side of the wall? A loft (so bare brick that you can check to see if it has any moisture on so you know if you have a problem) or a bedroom (with wallpaper that is bubbled and is coming away from the wall so again you know if you have a problem). I'm sure you will have done so already but do check to see what the inside wall of your house looks like and if there is moisture you know there is an issue. I was told by a roofer that the area around the chimney is a known weak spot however it looks like you have had a new chimney (different colour of brick) so not sure of the quality of the work when you had your chimney replaced.
  2. Thank you Russell, that’s helpful to know that noise won’t be any issue but only because I have the loft. Thank you also Russdl re your helpful comments too re noise. Really interesting to hear you wouldn't go for zinc but from what saveasteading says it sounds like the roof will be made from steel. Thank you also saveasteading for your reply. The house is nowhere near the sea so that won’t be an issue but good to know that. I’m interested to understand more when you say, ‘It needs maintenance much sooner than tiles. Decades, but fewer of them.’ I was under the impression that a metal roof required less maintenance compared to tiles (as tiles can crack, etc and I did think with having PV panels on the roof replacing cracked tiles may be a bit tricky and the metal would be sturdier). Re maintenance what do you mean exactly when you say, ‘Decades, but fewer of them’ please? I am under the impression that a metal roof can last 40 to 80 years but am unsure what maintenance is actually required. I’ve read some people say a clean is required but I will need to bear in mind there will be PV panels on one side of the roof. I’m not entirely sure why the developer is using a metal roof. I presume due to cost (but the house will be expensive/definitely at the high end of values for the lovely area it will be located in) but the developer’s architect did say metal roofs are good for attaching the PV panels to but I’m not sure if that is the real reason and whether it is simply due to the developer wishing to save money on the cost of the roof. I’d be very grateful if you could kindly elaborate on the level of maintenance required for a metal roof compared to tiles please as to date, from what I had read, I had been under the impression that there was less maintenance required with a metal roof. I suppose just say the developer did come back and say if you prefer tiles you can have them I'm genuinely not sure (due to the PV panels) if tiles or a metal roof would be better? My thoughts have been tiles may be tricky to replace if there are PV panels on the roof and I had thought there would be less maintenance required with having this type of metal roof? Really grateful to hear your views please.
  3. Thank you for your reply. No, unfortunately, the developer has not offered anything else. The only details provided are that it will be a standing seam metal profile roof. I am pleased to hear though that you say your roof looks spot on as the appearance of it is my biggest concern. I did wonder though if I might be given a choice of metals, e.g. aluminium, zinc, etc. I think the colour of the roof will be a dark grey/black colour which I don’t mind the colour of. I’m not sure if one metal is preferable to another and of course the weight of PVs on the roof will need to be taken into consideration by the developer. Can I ask regarding your metal roof what the noise of rain is like if you are in your upstairs rooms please? The proposed house that I’m interested in purchasing will have a loft (used for storage) which would surely mean the noise of rain wouldn’t disturb me when in one of the upstairs rooms?
  4. Hello I’m hoping you could kindly provide me with the key points that I need to consider please. I am very interested in purchasing a new build home (not yet built) and the house will be built to Passivhaus standards however my query relates to the roof. It is proposed that the house I would like to purchase will have a standing seam metal profile roof. I don’t yet know what metal will be that will be used for the roof and I'm not sure that I will be given a choice. It is also proposed there will also be PV panels on one side of the roof too (south facing). I do work in the housing industry but I’m not familiar with standing seam metal profile roofs. Are there questions that I should be asking the developer please? I did read that metal roofs can be noisy in the rain but I don’t know if that will be a concern as there will be the loft space between the roof and the bedrooms. I’d be very grateful to hear of any key points that you think I need to consider and wondered what people’s opinions are of standing seam metal profile roofs are please? Thank you very much for any replies.
