Hi,
Currently having a flat roof extension built on to the back of the house which has a "warm roof" on top.
The roof is finished to GRP level, The build up was completed by the main builder and the GRP applied by a separate roofing contractor.
Whilst finishing the GRP it was pointed out that the build up was incorrect and VCL layer had been left out on top of the OSB3 below the insulation level, the current build up is as follows (inside out) -
1. Joists
2. Furrings
3. OSB3
4. Celotex foil backed insulation
5. Kingspan foil backed insulation
6. OSB3
7. GRP
The builder missed the VCL between 3 and 4, As its impractical to remove the full roof this close to Christmas (which I'd prefer!) we're trying to come up with options to add in a vapour barrier below number 3 (internally).
The builder suggested adding 1 inch kingspan between the joists and taping but from reading up this would cause issues creating a hybrid roof system, The only plausible option offered by my architect other than to remove and re do seems to be to add a VCL (Visqueen or similar) continuously across the underside of the joists, Add 50mm battens or similar along the lengths of the joists to hold the VCL in place, attached foil back plasterboard to the battens to create a secondary VCL which creates a void to run cables and downlights without damaging the new VCL layer.
With this method the build up would be as follows -
1. Foil backed plasterboard
2. 50mm batten
2. VCL (Visqueen or similar)
3. Joists
4. Furrings
5. OSB3
6. Celotex foil backed insulation
7. Kingspan foil backed insulation.
8. OSB3
9. GRP
Would this be a correct way to preserve the new roof? Or can anyone suggest another option, Although not ideal it seems like a best case scenario currently.
Can anyone advise if the VCL being relocated from between the OSB and insulation to below the joists is likely to cause issues within this area trapping moisture or causing rot, mould or damp etc to form anywhere above or below it?
Thanks in advance, I am not a builder so apologies if my terminology is wrong on anything above.
