Kacha
Everything posted by Kacha
  1. Hello. I hope all is well. We are stripping paint and prepping door frames before painting. Any advice on what the best way to remove door stops is? I have tried a crowbar and hammer - it worked but is very noisy and I am afraid it could damage the door frame. PS. Please let me know if I should start another thread on this.
  2. Thanks.
  3. Thanks - is that including materials?
  4. UFH pipes? If so, were they under/in screed already?
  5. Hello. I hope all is well. We need to have the following done: pipes brought up from under the floor board, for two bathroom sinks pipes brought up from under the floor board, for a shower pipes brought up from under the floor board, for towel radiator connect concealed shower valves to pipes connect valves for bathroom sinks waste pipes for the sinks, toilet and shower connected to external soil stack install and connect frame for wall hung toilet connect soil stack Any ideas on how much this should cost? We will also need to dig and connect the new soil stack to the existing drainage.
  6. Hello all. I hope all is well. Update: insulation/PIR is in the floor. We were let down by the UFH guys we'd booked. So had to find a more reliable company, who will be coming in on Monday. Frustrating as we'd wanted this in by now to protect the PIR, but alas, we are where we are. Screeding should happen the day after pipes are laid (or very close to it), I am told by the builders, and then that is the floor done!!
  7. Thank you. Yes, BC have confirmed this. I will google search "list of statutory inspections" and see what I can find.
  8. Thank you. You are right. They said they need to see it after dpm and before concrete. So they will be visiting tomorrow. Hadn't thought about the photos for this purpose. However, luckily, I do have loads of photos as I am documenting the process for our own memories. 😊
  9. Ah - I see. Thank you.
  10. Hello. Would you happen to know when building control need to come in for an inspection. Is it after the concrete has been laid, but before insulation? Or after DPM, but before concrete?
  11. Hello. Quick update - second SE has come back and we are good to go!! Thanks for all your advice & guidance so far. It is very much appreciated.
  12. I suppose. 🥴
  13. Yes. That is true. Let's see what the second SE says. Second SE has gathered a lot of additional information on the property, so whatever the outcome, we will be more comfortable with the decision. First only asked about foundation depth.
  14. Tell me about it! We did a basic cost benefit analysis......before this spanner in the works 😩 Waiting to hear back from another structural engineer. 🤞
  15. Building control have come back to say the 500mm dig is fine. I am reaching out for a second opinion. So much fun!
  16. Thank you. We've made a start but had to halt as the SE we engaged, for the load bearing wall calculations, has said he thinks 500mm is too deep. The builders think otherwise. We're waiting to hear back from building control, and maybe get a second opinion. Super frustrating to have to pause - also worrying because as you've mentioned need to build it back up asap whichever route we go. Building control have been to the property previously (before this phase of work), we told them our plans for the dig out and were fine with all of it. My head is spinning 😩
  17. Thanks. Sounds like a lot of work! We had to dig to expose the foundation to put in steel beams. The foundation is 800mm from the finished floor level. Any ideas how deep a safe dig would be?
  18. Hi - quick question, do you know how deep your foundations were/are?
  19. Thanks for this - really useful. I will speak to the electrician regarding the waste pipe for cabling.
  20. Hello. I hope all is well. Update - the house has been stripped (well except for the wallpaper which we are tackling this weekend 😩 ), we have also gotten our drawings back from the structural engineers plus we had our first visit from building control today - it went well. The electrician starts work on the rewiring on Monday, and the plumber is in the following week - first fix. We also dug a trial pit and are well above the footing and/or foundation. Question - I have received two different quotes with material lists to reinstate the concrete floor. What are your thoughts on each one? First Quote - 520mm dig out MOT Type 1 - 100mm Sand 50mm Dpm Concrete 100mm Celotex PIR 200mm UFH pipes Screed 70mm Second Quote - 495mm dig out Hardcore compacted - 100mm Sand blinding 20mm Dpm 1200 gage Concrete base C35 100mm Dam 1200 gage Celotex PIR 200mm UFH pipes Sand and cement reinforced fibre screed 75mm Thanks!
  21. Hello. Apologies for the delayed response. We have a quote of £3,950 to dig up to 460mm. Have you received any quotes yet?
  22. @Andehh, got it. Thank you.
  23. @Temp, thanks - we are planning on laying ceramic/porcelain tiles. @saveasteading thanks. Does the fact we are using Wunda which come with trays/panels with grooves for the pipes change any of this? Wunda have told us we can tile right on top of the pipes/trays for an even better response time. However, a thin layer of say slc is recommended to protect the pipes in the event you need remove the tiles. Does any of this change your recommendation?
  24. @Andehh oh, I see. Thank you.
  25. @Iceverge, sorry - any concrete in your suggestion?
