Saints1
Everything posted by Saints1
  1. I haven’t but I’ll certainly look at it, thank you
  2. It will be an MCS install i am having three-phase electricity supply if that makes any difference. I am very new to all this so please allow for my lack of knowledge. Don’t have any power cuts whatsoever.
  3. Good evening all, I wondered if anybody could help. just trying to do some calculations in regard to our self build and solar panels. So within my plan I have added 16 integrated 410wp Marley solar tiles to be fitted on the roof. Although this has been calculated, one thing that hasn’t is what size inverter and battery for storage. I just wondered if there is anyone out there that has some good knowledge in this field? To give some perspective on the build it is a fair sized 4 bedroom detached house (approx 300square meters) that will have 2 electric vehicle charging ports and an ASHP. There will be two adults and a teenager living in the house. Any help or advice is greatly appreciated.
  4. Thank you to all of you, especially those who have been in similar situations and it’s useful to see that others have had similar dilemmas in regard to multiple utilities sharing the same trench. Also really useful knowing what others have been charged and it shows there’s no real continuity between prices, in essence each utility throughout the country just charge what they want. It appears that my quotes so far seem to be around the ball park figure of many others that have had similar work so it has offered some reassurance but I’d rather have many £1000’s in my pocket than lining the pockets of these companies. thank you once again all of you.
  5. I did query this with United utilities in regard to linking in with the gas supplier and utilising just one dig. The case manager practically laughed at me and just said “no we don’t do that” Im just amazed that local authorities don’t insist on this happening when confronted with similar scenarios. Surely they don’t want the road lifting twice……. Having said that, it’s probably more money for the council having to get two permits for road closure management.
  6. So if I find a local approved company and ask them to provide a quote solely on the pipe laying what are the chances of it being substantially lower? I mean if we are talking near £1k saving it’s 100% worth it. I will look to shop around but I have a feeling I’ll have to bite the bullet, sometimes I feel the utility companies have you over a barrel. Thank you again though for taking your time to help me.
  7. Many thanks for your reply… They have provided a breakdown (water) so to speak of contestable work and none contestable but I can’t tell from the breakdown what’s what… I’ll add it to here and see what people think and if you can deceiver it a bit better (or a lot better) than I can.
  8. Hi all, I wondered if anybody could shed some light on some of the quotes I am getting back from utility companies with regard to new connections. Whether they think they are reasonable or not? United utilities have quoted £7k for a water connection. Now the mains water is on the other side of the road so this cost includes them digging the road up and bringing it to my boundary (approx 7 meters from mains to my boundary) I will be doing all the trench work on my own property and leaving them enough pipe work for them to connect on to. Scottish power have quoted £4k to install 3 phase to my self build. Luckily the mains electric is on my side of the road so it’s a 1 meter dig of the public footpath to connect on to. Again I’ll be digging the trench on my land and placing the relevant ducting in. The gas company have not provided a quote yet as they state that there is no point until there is a gas box built in to the property for them to connect to as it will probably be past April next year when this will be completed and by then there charges will have increased. I do know that the main gas pipe is again on the opposite side of the road with the water main. So this will be again another digging and trenching across the road scenario…. so…. Water- £7k electricity - (3-phase) £4k gas - Unkown 1) Do the above quotations sound reasonable? 2) Does anybody have any previous knowledge or similar situation in regard to gas being located on the opposite side of the road and could provide details of how much they were quoted?
  9. Thank you all for your advice, I spoke to the architect today and he has agreed that block and beam isn’t required. To be fair to him, he hadn’t finalised all the drawings as there have been some too’ing and throwing between him and SE and he did state it required a re-design. If I hadn’t of come on here and sort advice I’d of probably let it go. Maybe the architect may have changed it regardless but at least I was forearmed. thank you all again. i am sure i will have many more questions to come considering i am very early in to the project 🙂
  10. Hello and thank you for your quick response. so there is a mine shaft on the site situated about 9 meters from the property however this has been capped at rockhead. The survey completed on the ground came back with good ground albeit made ground over the shaft entrance which is to be expected but the build is over 9 meters away from that. this was the originally reason for piling however structural engineer has stated rafters now which is fine. there has been no subsidence in the area ever recorded either. I just felt it was a little strange to put a raft then a block and beam flooring in.
  11. Hi all, I feel like recently I am constantly on here asking questions and nagging everyone but I value everyone’s advice. I am just getting my plans back from the structural engineer to submit to the BCO and they have gone from piling to a raft foundation which is fine. My architect has now stated that on top of the raft I will need a block and beam floor. I just wanted to query is this normal practice? I understand that I will need to insulate above the raft but I was hoping that I could insulate and then 75mm screed on top with UFH? I am no way a builder or in the building trade so could be way off with my theory but any help or assistance is greatly received.
  12. No nothing agreed… in essence I don’t think the neighbours knew where there pipes ran and probably didn’t concern themselves too much as long as their sh*t didn’t flow back they wasn’t that bothered lol
  13. Yes the neighbours property was built in 2000 whereby they knocked down the previous house and rebuilt on that plot so I’m assuming the sewer lines belong to the utility company with what you are saying pre 2011 but they just don’t hold the mapping for it?
  14. On the plans there is a pre-commencement condition that states “Foul and surface water shall be drained on separate systems. Surface water shall be drained in accordance with the hierarchy of drainage options in National PlanningPractice Guidance” I have looked at SUD’s however having had to do a site/contamination/Soil investigation the ground is very heavy clay with rock head found as shallow at 3.8meters deep so in essence the surface water will struggle to soak away. My neighbours house I know was built in 2000 and there was an existing house there before so my guess they connected up to the old pipes from the previous house. from speaking to the structural engineer in cases where I can’t get around SUD’s I will still need to put them on two separate systems (foul & surface water) even though they will meet in the combine sewer. But this will apparently future proof it incase the utility companies decide to devise separate drainage in years to come.
  15. Hello, I wonder if anybody could help. We are at the start of our self build project, planning agreed just going through fine print of the pre-commencement conditions. (Also of note this plot was a garden, so there are no services to the plot) I’ve been looking at how we are to get foul water and rain water away from the address and it looks like the whole road are on a combined sewer. I understand that nowadays utility companies want you on separate systems albeit they will eventually connect in to the combine pipe individually. The issue I have is I know the waste water flows at the back of my address as I know the neighbours and they allowed me to open the last manhole on their property. Their pipe runs straight across my back garden and then presumably in the neighbour on the other side of me. I have contacted the utility company to ask for a waste water pipe line map however they don’t have it for my neighbours either side and it only picks up on their system two doors down. The lady on the phone stated that they won’t hold maps for private sewers. so here’s my question, if my neighbours waste water flows across my garden can I effectively “T” into it (with the appropriate inspection chambers) at two points, one for foul water and another for surface water (two separate systems) and do I have to notify the utility company of this if they hold no records of it?
  16. Did you manage to find a suitable company in regard to your self build. I am finding myself in a similar position whereby I am using multiple contractures from brick layers, roofing joiners and “managing” the build myself but all insurers are interested in is who is the building contractor.
  17. I think the reason for the covenants was due to the fact the previous land owners (now deceased) had bought the land from the council at the time for a nominal sum. That’s when the then council (no longer exists) have put the covenants on that the land may only be used as a garden for the property to which the land owners have entered that agreement with them and as such the covenant has come in to existence between both parties. If that makes sense.
  18. Hi all, Looking from some advice. I have looked through the forums on here but can't really find anything specific to my issue. I have a plot of land that my parents own to which I am hoping to build a house on for myself. Full planning permission has been granted by the LA however when I have come to get the land transferred in to my name, my conveyancer has noted a covenant on the land from 1983 by the previous owners who are now sadly deceased. The covenant is between them and what was the county council at the time however this was disbanded in 1986 and the local authority took over. The covenant states for no dwelling to be built upon the land which is exactly what I was hoping to do. I did consider taking out an insurance indemnity on the land/property however when I spoke to my solicitor they stated that effectively we have already give notice to the LA by applying for planning and so no insurance would be likely to accept it as they usually ask for no contact/notice with any interested party. So my question is what are the possibilities of the covenant still being enforceable seeing that the primary persons involved are now deceased and the other party cease to exist. Do you think it would be reasonable to ask the LA for a deeds of release along with my parents, the now land owners? Any help or advice is greatly received.
  19. Dug to suitable strata which was bedrock at 4m. 6x6 m squared then reinforced with 25mm rebar then chairs 400mm high then 16mm rebar on top of that, then filled with R35 concrete 700mm thick. Left to cure then backfilled.
  20. I was equally interested… its a mine shaft from the late 1800’s it’s plotted to be around 80-100 meters deep according to the coal authority whom state is shallow as many mines went as deep as 500 meters so I’m told. It had to be capped at bedrock which was thankfully around 4 meters deep. The shaft diameter was 2.9 meters and so the cap was capped squared 6x6 meters reinforced with streel and 32 cubic meters of concrete 700mm thick.
  21. Hi all, I wondered if anybody knew if I could claim back the VAT on the cost for capping a mine shaft on site. planning permission has been approved with conditions, one of which is the capping of a mine shaft on the land certified by the Coal authority. This work has been completed but wondered if I could claim back the VAT as part of the build as without this work being completed the house could not be built so it was necessary for the overall development of the dwelling. Any advice is greatly welcomed
  22. Thanks for your replies guys. Really helpful and food for thought.
  23. I am currently going through the same process with my LA that have placed a lot of pre-commencement conditions on the build, one being a landscaping plan. I have read on other post people who have completed their own to keep cost down but I can't seem to find an online software that will enable me to complete one. I say I can't find one, I can find loads that all come with a cost/subscriptions. I don't suppose anybody out there has any knowledge of any sites/software maybe free? Thanks
