MasNovice
Everything posted by MasNovice
  1. Ok thank you, could I just clarify, is it correct I don't need to focus on Airflow so much, even though I have so many turns?
  2. Thank you JohnMo, so this makes sense, (keep close to the hob) so for the smell extraction is there a model you would recommend? It sounds like a lower airflow rate 302m³/h is fine, I would just want one which is easy to keep clean! Thank you
  3. Hi all, I wonder if you could guide me, due to a terrace, we have to use flat ducting to go round a nib, through to an extension wall for the external ducting. There will be 5 lots of 90 degree turns for the ducting to take. I'm looking at Luxair to gain the most powerful Airflow rate of approx 500 m3/hr , as the width of the canopy is between 51cm and 54cm. Would it be correct I will gain some level of extraction I'm looking for from steam and smells? The Kitchen is open plan at approx 6m x 5m. Thank you so much.
