Greenjefe
Greenjefe's Achievements
New Member
New Member (2/5)
0
  1. Hi all, I have a corner en suite shower tray that has a 5" long x 1" wide narrow slot as the drain, letter box shape. Has anyone any idea what makes this tray might be. There is a problem with the waste trap, it's as if there isn't one fitted, it must be linked to the toilet outfall, there is a stench from the shower drain every time the toilet flushes and you can hear the water gushing through the shower drain. I get the feeling I may need to remove the shower tray to investigate what type waste trap may be fitted in case it is damaged or non existent. This is a Redrow build BTW so has anyone had any experience with this type shower basin waste fitting or what the manufacturer is should I need to replace it or if the waste connection is a bespoke type.
