Morning all,
Long time reader of the forum, and joined yesterday to get some advice. I am going to cut a long story as short as possible:
I have been self renovating a house for the last 3 years which has involved architects, structural engineers, planning, going back to bare brick, new electrics, new plumbing, insulating etc etc. The final part of the 2nd extension (double storey side) is near completion and the roof now needs doing,...this was going to be something that I pay someone else to do and just hand the plans over, but I have unfortunately been made redundant and as such am currently on leave for the next 6 months so I am trying to use the time wisely,...
So thats the background, my query is regarding the plans and how to join old to new:
- My existing house is of solid brick construction at 225mm wall thickness, which means the wall plate will sit on the outer edge of the 225 brickwork. However, with a cavity wall setup, the wallplate needs to be on the inner leaf meaning that the inner leaf brickwork will have to be built higher to accommodate the birds-mouth, correct? This means that the restraining / joining horizontal timbers that join the bottom of the rafters together will sit higher? The challenge is that there is a loft conversion going in too. The new side extension is set back 225mm to be subservient, but this also had to be minimised it to retain the head height in the dormer at the back - The roofline was originally planned to be in line with the existing, but the planners requested the roof be set back too, so the plans were adjusted and the new steel cranked beam was offset.
Regardless whether I go with the 'set back' roofline or break the rules and go with the original plan of the continued roofline, I am still struggling to understand how the construction is setup and the floor height will be the same? Because, in my head the restraining timbers will need to be correctly planned and they will go 'through' the blockwork for the inner leaf? The plans detail the connections, wall plates etc but I assume that a roofer would know this when I handed the plans to them, but as that's not happening now, I am struggling to understand how the floor height is maintained with a different wall construction unless the floor timbers go through the blockwork?
If you've not already figured it out, I overthink!!
Looking forward to some advice, and apologies for the lengthy message. I can share plans etc if required.
Thanks in advance.
