Hi all,
Can someone please help & advise me of the best way forward.
About 2 years ago I had new UPVC windows fitted & due to a noisy street location, I had acoustic double glazed glass. I elected to have no air vents, as this sort of conflicted with the reason for acoustic glass.
In pouring rain, I have zero leaks or water ingress.
The window fitter used a 2'' section of plastic trim where the inside of the new window meets the plasterboard.
However, the bedroom when it is cold outside the obvious condensation appears on the inside of the glass. I expected this on the glazing, which is fine. However, where the 2'' plastic trim ends in the reveal, I noticed the painted plaster board was discolouring all along the edge of the plastic trim 'as if wet/damp' in the morning & damp in both bottom corners, with the paint peeling off & signs of damp spots in the bottom corner.
I could only assume that there was condensation building up actually on the inside section of window frame and leaching on to the plasterboard reveal, if this is even possible??
As this happens when it hasn't been raining & hadn't been, so no concern over water ingress/leaking. So can only assume it's condensation!?!
After now removing the 2'' plastic trim & cutting out a section of the plastoerboard where it meets the UPVC window, I can see there is nothing between the window frame and the external layer of house brick, pictures below. It actually feels markedly cooler in this area & it has been pouring with rain this last week or two & the inside is bone dry. It just feels cooler in the void.
My house is approx 20 years old & built by Taylor Wimpy I believe.
I know the window fitter sealed the external sections where the UPVC meets the brickwork, with silicone sealant. But should he have also used some expanding foam for between the UPVC & brickwork which I would then see from the inside, as nothing can be seen in the pictures?
Searching on this forum, I think I need to use some expanding foam in the small gap (it does appear very small) between the window frame & brickwork on the inside. Would I then need to use some vapour tape round the whole join between frame & brickwork & then fill the entire gap/void, before re-plastering?
Also, what should I use to fill this gap, it looks like there is some form of cement covering the insulated gap between outer/inner bricks & a DPM?
Thanks for any expert advice.
Iggy
